2021.3 graphics glitch?
Since updating to 2021.3 I've noticed an intermittent graphics glitch in the bottom half of the screen when using Pro Tools. It happens infrequently and seemingly at random so I haven't been able to really troubleshoot whether or not any particular action I take is triggering it but it doesn't seem so (it's happened in a plug-in heavy mix session and also in a simple tracking session with very few plugins). It's a quick flash of white/black blocks in the lower part of the display.
I'm using a MacBook Pro and I've seen this happen both on the built-in display and also when connected to an external HP Z27 display with the MBP closed. I've only seen this glitch in Pro Tools, and only since updating to 2021.3. Anyone else have this issue?
Mac mini M1, 16 GB RAM, Ventura 13.3.1, Pro Tools 2023.3, Avid S1, UA Apollo Twin UAD-2 Satellite |
Re: 2021.3 graphics glitch?
Yes, same here. After Clean install Of Big Sur and clean install Of PT I have a random Glitch. Inviato dal mio iPhone utilizzando Tapatalk |
I have the same thing happening. I’m running a MacBook Pro in clamshell with an oled monitor and have had this happen a bunch since the update.
I have the same thing as well. It's like monitor flicker. I'm figuring it will get put on the list of stuff to get fixed...
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
Everything's fine on my system, for the record.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
It happens if you select a section of a wave file, the screen under your section has a slight flicker, almost like a page refresh, or better yet, back in the day when you'd point a video camera at an old school tube-tv set. It only does it under certain conditions.
I get a freeze every 10 seconds on my Win 10 machine. Annoying at best. Nvidia just released a new driver for my graphics card. We’ll see.
It happends on mine too. But I'm on a M1 Mac Mini.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
Same thing here. 2020 iMac 27 inch 5K monitor. I see it mostly in the edit window and it will be horizontal along a track often times when it’s in volume at not waveform view. And it doesn’t happen in the same place on the monitor all the time. It has something to do with the actual track itself I believe because the graphics glitch appears to follow the length of the track.
Does anyone notice the fader levels becoming glitchy and not snappy once you open few plugins while the mix window is open as well ?
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
Graphics glitch every 60 seconds in 12.5 [SOLVED] | DJ Hellfire | Pro Tools 12 | 5 | 03-29-2018 01:29 PM |
Graphics glitch in 12.8.2!! | Cryos | Pro Tools 12 | 3 | 12-12-2017 11:51 PM |
Air Plugins Cause Graphics Scaling Glitch on 4K Display | jarwady | Pro Tools 12 | 10 | 07-03-2017 03:51 PM |
Anybody sees this graphics glitch? | Meads | Pro Tools 12 | 12 | 09-03-2015 10:46 AM |
PT8 - Pan Window Graphics Glitch | JamesH | Pro Tools TDM Systems (Mac) | 0 | 08-19-2009 10:04 AM |
