Old 03-08-2018, 12:06 AM
annapretorius annapretorius is offline
Default Speaker hum when ProTools launches
Hi there
I am running Protools 12 with the Avid fast track duo and rokit 5 powered monitors.
As soon as I launch Protools, the speakers starts to give a high pitched hum. This remains constant and only goes away when I close ProTools.
I cannot hear the hum through the headphones.
Can anyone PLEASE help me? I am so annoyed!
Old 03-08-2018, 05:42 AM
Bookerv12 Bookerv12 is offline
Default Re: Speaker hum when ProTools launches
Hmmmm.
Are the speakers and interface plugged into the same outlet?
Try plugging computer, interface and speakers to same plug.
See if that fixes it.
If not, ...
Are you using TRS cables to the speakers? (three conductor plugs)
It sounds like noise is being amplified by the speakers.
Can you plug in another piece of gear to the speakers to rule them out as well?
bookerv12
Old 03-08-2018, 08:50 AM
Originally Posted by Bookerv12 View Post
Hmmmm.
If not, ...
Could be a ground loop like you're suspecting. Another issue might be the power supply internal to the monitors is humming as it's probably a switcher supply and not the old-fashioned linear supply.
Old 03-09-2018, 12:17 AM
Hi there
The speakers and computer are all plugged into the same multiplug.
The fast track sound card is powered through USB.
I am using TRS cables between the speakers and the interface.
Old 03-09-2018, 01:03 AM
The hum starts as soon as anything starts that generates sound.
IE: Hum starts when launching ProTools
Hum starts when playing video on quicktime.
Old 03-09-2018, 03:07 AM
notable's Avatar
notable notable is offline
Is it like white noise? Kind of a hiss that is a background constant and goes up to minorly audible 30dB when you crank your speakers up?
Notable.com
AfricanUnderground.com
DemocracyinDakar.com
NomadicWax.com
Old 03-09-2018, 03:15 AM
notable's Avatar
If yes... I've seen this with noisey power feeding yamaha powered monitors. The solution was power filters on the powercable that fed the monitors and balanced cables feeding the audio to them from the interface. Also test the grounding....One cheap test for grounding issues is trying 50 cent ground lifts on the speaker power cables.
Notable.com
NomadicWax.com
Old 03-09-2018, 03:46 AM
Sardi Sardi is offline
I posted in the other thread but that seems to have disappeared. Perhaps a mod deleted it as it was a duplicate.
If it’s high pitched whine, it’s more than likely coming via the USB bus on your computer. It’s not uncommon unfortunately. Power filters and isolators are what you need to try.
I had it in the past on an iMac and the only thing that totally got rid of it was to lift the ground/earth on the iMac power. Its not recommended for obvious reasons, but I knew the risks and did it as a short term remedy as the USB interface was a stop gap whilst I was deciding on an interface upgrade as I prefer FW.
As mentioned above, lifting the earth on your monitors will achieve the same thing.
Old 03-09-2018, 04:36 AM
I had it in the past on an iMac and the only thing that totally got rid of it was to lift the ground/earth on the iMac power. Its not recommended for obvious reasons, but I knew the risks and did it as a sort term remedy as the USB interface was a short stop gap whilst I was deciding on an interface upgrade as I prefer FW.
And I thought cheesegraters were the only ones that had the USB whine problem? As I remember reading about it it was mainly the USB ports on the front of the computer that had the noise and the others were okay. First I heard about iMacs having that issue.
One of the reasons the USB ports can have noise on them is due to the type of power supply used inside. They use a switch mode type of supply that's basically an oscillator running at a high frequency to regenerate the incoming AC mains. It's one way they can get around having one power supply in all their computers that can run anywheres in the world. All one has to do is to change the plug end that goes into the wall socket (or they give you different power cords).
Old 03-09-2018, 07:00 AM
I also tested it on a windows system. When I play anything through the fast track duo and the same monitors, there is no hum. Only happens on the mac.
Center Speaker Output playback on Left & Right speaker Ayem Ismail Pro Tools 11 2 01-08-2017 11:05 AM
Speaker Noise only when PT launches Mdubbs818 macOS 1 08-11-2013 04:29 AM
Aggregate I/O Built-in Speaker causing speaker to crack and pop andrewkeithly macOS 2 01-27-2012 11:10 AM
ProTools launches slowly Nippamuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-07-2003 06:40 PM
mbox protools new session launches then crashes MoreMeintheMonitors 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-13-2003 12:00 AM
