controlling triton with protools thru Radium
I got a triton hooked up to my mbox and thru midi thru my radiums usb. everything works like if i play the radium it uses the tritons sounds and protools records the notes but when you play it back you get no sound. i have a stereo audio channel with the sound but if i try to use protools to type out the notes or after it records the notes i get no sound. theres gotta be just 1 thing im doing wrong.
i7 920, Gigabye ud4p, 12gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black 1x Samsung 120gb SSD
HACKINTOSH Mac OSX 10.8 Pro Tools 10.2 OLD Dverb 1024 - 520 Dverbs 64 - 433 Dverbs NEW Dverb 1024 - 283 64 - 235 |
Re: controlling triton with protools thru Radium
Do you have local control on/off set to off on the Triton?
was on now off but still nothing when we playback what protools recorded.
Do you have midi thru 'ticked' under the midi menu in PTLE?
Do you have the audio track's input set to inputs of the mbox and the fader up? The only other suggestion I have is to ensure MIDI Beat Clock is enabled, but it shouldn't make a difference. Otherwise, it sounds like a problem with midi data not getting back to the keyboard which would be a problem with the Raduim (you do have the latest drivers from their website?). Is your midi input channel set to 'all' and the midi output channel set to one of the midi channels? Is your keyboard in sequence mode? |
Radium 61 not working with Protools LE 8 | Amp Doc | FireWire & USB Audio Interfaces (Win) | 1 | 04-18-2013 12:07 AM |
controlling the triton studio from pt8 | rudyrhythmz | MIDI | 2 | 02-05-2009 07:37 PM |
controlling the triton studio with protools | awan | MIDI | 1 | 04-15-2008 12:29 PM |
Controlling Protools remotely | orourkeaudio | Pro Tools M-Powered (Win) | 0 | 01-07-2007 07:07 AM |
Triton Le controlling Pro Tools | Nana Sarpong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-04-2006 12:58 AM |
