Old 06-02-2011, 03:35 PM
galek galek is offline
Smile Expansion Pack Big Help Need !!!
Hi.
I'm from Poland.
I have bought 11 -and Expansion Pack several day ago.
I wan't to activated and go Expansion Pack and when i started the activation setup program i have command like that:
You have reached the maximum allowed activations for this serial number.
Allowed Seats for this serial number: 1
Currently activated seats: 1
Attempted Amount: 1
What can i do with this problem ?
Did i must contact with the former buyer ?
Thanx for help and i'm sorry for Errors in writing :)
Regards from poland !!!
Old 06-02-2011, 03:48 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Expansion Pack Big Help Need !!!
Im not clear on what you are asking?
Did you buy the ERXP for a third-party? or the 11R used?
If firmware 2.0.1 is already on your 11R, there is no need to re-install the firmware part.
If you have not updated to 2.0.1, and the ERXP Firmware updater is not accepting your Serial number, then you need to contact Avid.
Old 06-02-2011, 06:04 PM
hey. I bought 11R and the CD with EREP. Unfortunately, you can register only once EREP and I'm not sure if they are loaded by the previous owner.
Old 06-02-2011, 06:25 PM
Benoni's Avatar
I was not aware they were shipping the ERXP in DVD form.
If you purchased the 11R second hand, and the ERXP was the property of the First owner, more than likely he has already updated the Eleven Rack.
Turn on your Eleven Rack , hit Edit once, scroll to AMP, and look scroll through what Amp models are available. If you see RB-01b, Black Mini, ect... the Firmware has already been updated, and there is no need to update the firmware again.
Also try this. Turn on your Eleven Rack. HOLD the Edit/Back button for 2 seconds and it will drop you in the User Options menu.
Scroll to the Last page, hi-light FIRMWARE VERSION, hit SW1 to select it,
and read what version is installed. If its version 2.0.1 you do not need to do anything else.
Old 06-02-2011, 06:50 PM
Ok. I checked everything you said. Firmware 2.0 Build 0.1.5.3
EREP is already installed. Thanks for your help and greet warmly.
I am already calm:)
Many thanx :)
Do I have the Expansion Pack? strangedogs Eleven Rack 25 09-10-2015 10:41 PM
A.I.R Expansion Pack VIs Becharax Virtual Instruments 7 09-24-2012 10:59 AM
expansion pack pinnacle Pro Tools 10 1 09-05-2012 05:46 PM
need help with expansion pack eddie7314 Eleven Rack 2 10-08-2011 02:58 PM
11R Expansion Pack in UK? connor66 Eleven Rack 6 07-24-2011 09:11 PM
