Old 09-06-2010, 04:50 AM
psycho_monkey psycho_monkey is offline
Default Waves 7 isn't working after installing iTunes 10 - FIXED!
EDIT - This is not an iTunes issue, it's related to a disk corruption....now the problem is solved!
I did...now Waves 7 isn't working!
They could be totally unrelated of course..but the only thing that's changed on my system is the update to iTunes 10. This morning, my previously rock solid LE rig won't load a session. Narrow it down to the Waves plugins in it (I have platinum and studio classics). Can open any session without waves plugs, or with all plugins deactivated. As soon as I try to open a waves plugin - spinny beach ball, and PT freezes.
Got a few things to try (latest version of Waves installers, latest PT updates) but just a word of warning. Waves tech support are looking into it for me.
Anyone else come up against this? if you have OSX 10.5.8/Waves 7/PT LE8/iTunes 10 on Mac Pro, I'd be interested to hear your exact versions for waves and LE, so I can see if I can rescue without having to system image my disk!
Old 09-06-2010, 09:53 AM
tamasdragon tamasdragon is offline
Default Re: Don't install iTunes 10 yet!
Oh, waves again?
I had so many problem with them I stopped buying and using them.
my blog:Tamas Dragon
Old 09-06-2010, 11:31 AM
paul_g paul_g is offline
Originally Posted by tamasdragon View Post
Oh, waves again?
I updated to iTunes 10 and am running Waves 7.0.0.21.
I'm running an iMac w/ 10.5.8, PT LE 8.0.4 and do not have the issues you are having.
1. Try trashing prefs...
2. Try creating a new Admin profile and logging in...
2.4 ghz Intel Core 2 Duo iMac
OS: 10.7.5 (Snow Leopard)
4gb (667 MHz DDR2 SDRAM)
LaCie Audio Drive - FW800
DigiDesign 003 Factory PT10.2.0
PreSonus DigiMax FS
Old 09-06-2010, 11:56 AM
hey, thanks for the replies.
Waves have actually been pretty good on the tech support so far.
I've done the usual prefs trash - they've given me detailed instructions for removing Waves totally and then re-installing. I've got the latest build of the installer, plus the 8.0.4 update so hopefully that might have some effect.
Old 09-06-2010, 01:41 PM
mattrixx mattrixx is offline
PTLE 8.0.4 & WAVES 7 working just fine here.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 09-06-2010, 02:12 PM
not just a PT thing apparently - Logic hangs when validating the first waves plugin...
EDIT - possibly not - it's just taking at least 2min to validate each waves plugin.
Old 09-06-2010, 02:13 PM
it doesn't here.
Matt McKenzie-Smith
mattrixx.net
Old 09-06-2010, 02:16 PM
Originally Posted by mattrixx View Post
it doesn't here.
Thanks Matt, you're obviously not suffering the same issues. It's obviously not a generic thing, but something in my system has been broken, possibly by the iTunes 10 installation. Just trying to narrow it down.
Old 09-06-2010, 02:24 PM
I am using Waves (GOLD version only) ver 7.1.0.3 build 6872 (if I open a RenComp or L1, I believe the build numbers will be different for the various plugs). Is this the same or similar version that you have?
Does it happen whether iTunes 10 is open or not? (works both ways here).
I guess the only other thing that I just noticed is that you are using 10.5.8. I am actually using 10.6.4.
Regards,
Matt
Matt McKenzie-Smith
mattrixx.net
Old 09-06-2010, 02:30 PM
Regards,
Matt
I was going by the build of the waveshell, but since posting I've uninstalled totally, re-installed with the latest build, and updated PT to 8.0.4.
Also just tried creating a new admin user. No joy there either - just spins whilst trying to load the waveshell.
Doesn't matter what iTunes 10 is doing - I'm not even 100% that's the reason it's not working, but that was the only change between a working system and a non-working one, so it's the prime suspect.
I mean, I know I COULD fix it by doing a re-install from scratch (at which point I'd probably go to Snow Leopard as well) - I actually maintain PT rigs for the studios I work at, so I didn't have a problem nailing what the actual problem was - it's just a bit of a weird one!
fortunately this is my 2nd machine really, my main rig is at my production studio (and is fine). I can still do edits on it, so I'm going to try to find a solution that doesn't involve wiping the whole thing, even it it takes a week or so.
Thanks for all the help so far!
iTunes will not track after installing LE 7.3 on Intel Mac kkinnon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-01-2007 07:25 PM
Digi 002 Rack no sound after installing iTunes 6 Jumper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-21-2005 07:37 AM
iTunes/Quicktime/Reason problem fixed nyaccino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-11-2005 06:57 PM
Waves exploding sound fixed in Ver. 3? Marzuki General Discussion 11 01-10-2001 12:52 AM
Waves 2.8 and HUI-- problem fixed? uno1234 Pro Tools TDM Systems (Mac) 2 10-29-1999 06:54 AM
