Old 07-17-2015, 08:27 AM
Avianer Avianer is offline
Default Expansion Pack Help
Hey guys,
Here's the situation.
I bought the eleven rack used. The person who I bought it from kindly said if i needed anything, to just let him know, so getting in contact with him isn't too big of a deal.
I purchased the expansion pack and already did the little patch issue on Mac OS 10.10 with the folder creating etc... so the error message is no longer reading licensing failed. It's reading system id and serial number don't match. Getting in touch with Avid is the most ridiculous thing ever, and I have a feeling that I'm probably out the 100 bucks I paid avid for an expansion pack I can never use.
Help please
Thanks!
Old 07-17-2015, 09:05 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Expansion Pack Help
Sorry, you will have to contact Avid so they can give you new numbers or reset the ones you have.
I guess you've already done this
http://avid.force.com/pkb/articles/e...=0&subfilters=
Old 07-17-2015, 04:26 PM
jeffro's Avatar
jeffro jeffro is offline
Started a support case to get your System ID and Serial Number. Please reply to that (check inbox and spam/junk), thanks!
Old 07-27-2015, 06:06 PM
Default Expansion pack help
Looks like I missed my support ticket and didn't realize it. Posting again, will check daily to get support
Hey guys,
Help please
Thanks!
Last edited by jeffro; 07-28-2015 at 10:32 AM. Reason: Merged with existing thread.
Old 07-27-2015, 07:22 PM
dcullipher dcullipher is offline
Default Re: Expansion pack help
I have the same issue. I update Protools to 12 and went through that process then trying to get Eleven Rack updated and was met with the mismatch error. Tried on my windows 8 machine then saw the issues there with IE. Now tried on my Mac and get the same error using the codes in the account panel.
All we can do is file a ticket and pray it seems. For some it took 3-5 times of getting codes before it worked. There is no number that I know of for purchased product install support which is pretty crazy.
Just know that you are not alone. Many others had the same issue. The rack is worth in when you are through it. But Avid has always had issues in this area for as long as I remember. It is amazing the amount if DRM they through at something that needs the hardware to work. unfortunately it is not backed up with support. Should have bought through sweetwater so I could at least cry with someone on the phone.
Old 07-28-2015, 10:22 AM
An update for you. Try calling the tech support line and selecting product registration. They were able to reset the number for me. Should have you up in no time.
Old 07-28-2015, 10:26 AM
jeffro's Avatar
...I purchased the expansion pack and already did the little patch issue on Mac OS 10.10 with the folder creating etc... so the error message is no longer reading licensing failed. It's reading system id and serial number don't match...
I'll re-open the support case, please watch for an email.
jeffro's Avatar
Glad to hear you got this resolved.
A.I.R Expansion Pack VIs Becharax Virtual Instruments 7 09-24-2012 10:59 AM
expansion pack pinnacle Pro Tools 10 1 09-05-2012 05:46 PM
need help with expansion pack eddie7314 Eleven Rack 2 10-08-2011 02:58 PM
Expansion Pack Big Help Need !!! galek Eleven Rack 4 06-02-2011 06:50 PM
PT Expansion Pack shstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-19-2010 11:21 AM
