Midi keyboard with Pro Tools Express
Hi, I have Protools 10 Express and I have just bought a Novation Launchkey 61 midi controller which I have connected via USB to my laptop (Windows 10 OS). The Youtube tutorials tell me to go to Set Up, Midi, Midi Studio and I should be able to find my controller listed but it isn't. In fact that tab looks different to the ones shown in the tutorials. If I go into Peripherals and open up one of the 4 coloured boxes under type my keboard is listed. Maybe I'm setting up the Receive from and send to wrong. I also keep getting an error message "Protools is unable to communicatewith M-Audio keboard...." which goes on to say check connections and update peripherals. All the tutorials say that its easy to set up a midi controller with Protools but I can'r seem to get mine to talk to each other. Please help. Thanks.
Re: Midi keyboard with Protools Express
A bigger problem though is you're using a combo of PT and Windows that are not compatible with each other. See this page: http://avid.force.com/pkb/articles/e...tibility-Chart |
Hmmm, compatibility might be the issue, but having said that, go into Setup>Midi>Midi studio again and click the Input Port "button" to see if the Novation is listed there(this is the place that really matters). It would probably look something like "Novation USB[Emulated]"(without the quotes). If it appears there, select it and test. If there is nothing there mentioning the Novation, it could be incompatibility or maybe you need to install a new driver(check the Novation website for Windows 10 drivers). Hope you have success. My own attempt at using Novation gear was a bust(but this was years ago)
Thanks guys for the replies. Jack, I have been using this combo of Windows 10 and PT for a couple of years with no issues up until trying to add this midi controller. Not sure how to turn off the power savings measures for the USB ports. I have been all through the settings in the control panel but can't find where I need to do that. Dave, if I go into the Midi studio set up and click import it gives me a warning message "Importing another Midi studio set up will replace the currently active set up. Do you wish to proceed?" So I didn't proceed cos I didn't know what I would be wiping.
Re Import, you don't have a working midi studio setup so you have nothing to import. In that window, create a new "instrument". Name it as you like(it makes no difference in function). Brand and model are also not required. The crucial setting is the Midi Input Port. Until that is set, PT doesn't know where to expect midi data
Hi Dave
Ok I have done as suggested, gone into midi studio set up and created a new instrument. My input port now gives me 2 options Launchkey MIDI and MIDIIN2 (Launchkey) and my output port also has 2 options Launchkey Midi (Emulated) and MIDIOUT2 (Launchkey Midi Emulated). Not sure which combinations to choose here, the launchkey I have is a series 2 some I'm guessing the second option on both. I then have send and receive channels both showing 16 channels hilighted in blue...... |
https://pattersonsupport.custhelp.co...ows-7-machines https://helpdesk.flexradio.com/hc/en...nected-Devices |
Pro Tools Midi: External Keyboard Input to Piano Roll's Keyboard | SupreGlu | MIDI | 1 | 05-16-2015 08:26 AM |
MIDI keyboard compatibility with Pro Tools Express | darthvarun | FireWire & USB Audio Interfaces (Mac) | 0 | 01-01-2015 08:47 AM |
pro tools express + windows 7 midi keyboard out!! | FMviolin | MIDI | 0 | 06-04-2013 06:06 AM |
[Problem] Midi Pro Tools 10.3.5 & Motu Midi Express 128 | Advanced-Productions | MIDI | 0 | 05-20-2013 09:43 AM |
Pro Tools Express & MIDI | beerninja | MIDI | 0 | 05-22-2012 07:49 PM |
