Old 02-09-2012, 09:24 AM
25ghosts 25ghosts is offline
Default Lion 7.3 = System Output not possible via 003
Hi...
I successfully use Protools 10.0 with my 003 Factory. No Problems.
Avid CoreAudio Manager also recognizes it and lets me make adjustments as usual.
Only, in Audio Midi Setup I cannot see the 003. If System Preferences under audio I dont have the 003 as option for neither in or output.
I have ran and installed all updates aside from PT10.1 but that should not be the case...
Do I need to install anything else ?
Thanks for your time
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 02-09-2012, 01:59 PM
Default Re: Lion 7.3 = System Output not possible via 003
I am going to have to revise this here post and beat my own arse...
I had problems with AVID CoreAudio Manager 6 months ago and moved it out of the HAL folder... Putting it back in helped
I installed PT 10.0.1.58 and hoped it would be better...
Here is the post to my findings... AVID CoreAudio Manager crashes any app that tries to use it... At least with the 003 Factory attached.
http://duc.avid.com/showthread.php?t=317176
Old 02-09-2012, 02:53 PM
RegenerationMix RegenerationMix is offline
you might have more luck or response posting this in the pro tools 10 section. And pro tools 10.7.3 is not officially approved yet by Avid.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
No output 3 and 4 on MP9 with fasttrack pro in mountain lion!!! rmsyster Pro Tools M-Powered (Mac) 9 05-27-2013 12:28 PM
Digital Optical Output 44.1k on StartUp OS X Lion kd_special Pro Tools TDM Systems (Mac) 0 02-07-2012 12:49 PM
OS X Lion, PT9, MIDI System, mbox 2 mini... thegordian macOS 1 12-02-2011 11:14 AM
192 output Dither.. output to Hear System Jeff E Pro Tools TDM Systems (Mac) 10 07-22-2009 11:41 AM
No Output with New System Allen Hallada Pro Tools M-Powered (Mac) 5 07-07-2008 10:52 AM
