Old 08-22-2006, 05:01 AM
Beauchampy Beauchampy is offline
Default Deactivate all plugins?
Is there a shortcut to make all plugins inactive/active? I don't mean bypass, I mean inactive (as in ctrl + win + click)..
Im tired of clicking on every single plugin (sometimes in excess of 100) before I can save a session.
I have to do this because PT will sometimes crash when I open up a session with lots of active plugins.
TIA!
Beauchampy
Old 08-22-2006, 05:31 AM
Kurdt Kurdt is offline
Default Re: Deactivate all plugins?
If you add "alt" to that command it acts as the global modifier. Though I believe it will only work for each row of inserts so you'll most likely have to do it once for each row. Still a lot better than 100's of times...
Add "shift" into that and you will only selected items.
Old 08-22-2006, 11:19 AM
Matt Whritenour Matt Whritenour is offline
instead of using that shortcut you can just ctrl + righclick i find that much easier then having to also hit the window's key
www.klarityrecordingstudios.com
Need to deactivate surround I/O in PT9// onepercentfree Pro Tools TDM Systems (Mac) 0 11-23-2010 10:37 AM
Need to deactivate surround I/O in PT9// onepercentfree Post - Surround - Video 0 11-22-2010 11:21 AM
Digi CoreAudio won't deactivate sophie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-17-2006 02:19 PM
IS THERE A WAY TO DEACTIVATE INSERTS UPON STARTUP? aecas Pro Tools TDM Systems (Mac) 3 08-07-2005 04:31 AM
Deactivate TDM plugins eurosurfer Pro Tools TDM Systems (Mac) 2 09-03-2001 08:01 AM
