Old 03-16-2004, 10:02 PM
jake9n jake9n is offline
Default Getting system sound output through the Digi oo1
Im running OSX and Le through a digi001 on a G4. I would like all my audio to go through the digi oo1, and I got ProTools and Itunes to do it, but my sytem output (warning beeps, web browser stuff, and real audio player) still come through my CPU speaker. I tried going to the Audio/MIDI settings in the Sytem setup thing, but it wont show Digi001 as an option for system output. In the sound setup for OSX, everything seems to be fine. Any ideas?
Old 03-16-2004, 10:11 PM
dans dans is offline
Default Re: Getting system sound output through the Digi oo1
I can't get to my 001 right now, but from what your saying, it's going to be a configuration issue in either the Core Audio setup or probably the Sound preference panel in System Preferences. You said you looked in there, but I'd double check. If iTunes is working through it, then Core Audio is installed and working. You just have an incorrect setting somewhere. If no one gives you the answer by Wednesday morning, I'll post back when I'm at my 001.
It's not what you know that is important...it's what you can figure out.
G4 1.25DP/FW800/1.25GB/OS X 10.3.5/Digi 001/LE 6.4
Old 03-16-2004, 11:50 PM
nedorama nedorama is offline
Couple of things:
Make sure you have the latest version of Pro Tools LE and the Core Audio Drivers installed.
To switch from internal speaker to your Digi 001, open your System Preferences app, and click on the sound icon. You should have a choice now of internal speaker or Digi 001
So you've done that, and it works -- you can also make sure that system beeps don't go through your 001 (usually a good idea to protect hearing and sanity) but you want games, DVD player, etc to work with your Digi 001, which doesn't happen automatically -- not a problem.
Open Digidesign CoreAudio Setup in your Digidesign folder. With this app, you can add other applications, (iMovie, DVD player) to the list of applications that will use your digi hardware. Works great.
Hope this helps.
Regards,
Ned
Monkey Boy Studios
2013 15" MBP, 16GB, 512GB SSD; OSX 10.15.6; 1.5TB FW800 External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2020.5
Plugins, Virtual Instruments, and real ones
Old 03-17-2004, 12:24 AM
clockface clockface is offline
Doesn't work great! Only one app can access the driver at a time. And since when is it possible to route system sounds through there at all? Are you sure about that? Have you actually physically done it yourself? Last time I ever used Core Audio (when 6.2.1 came out), it would only allow applications to utilize it, one at a time, not system sounds.
003 + OS10.5.7= No System Sound Output? mu-tron-kid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-29-2009 05:00 PM
system sound output selection dub guy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-11-2003 11:58 AM
PT6 and system sound output jkirk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-25-2003 08:29 PM
No 001 system or CD sound output dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-18-2002 12:03 PM
system sound output via HD jackruston Pro Tools TDM Systems (Mac) 3 04-14-2002 04:11 AM
