Triton and Digi002 Midi Time Sync Problem
Hi, Im new to this forum, and I have a problem. I have my Triton slaved to the Digi002. The triton only has 5 outputs, and I sometimes have up to 12 tracks to record. So I record the first 5 tracks. They sync fine. When I go to record the next five, It is not synced with the first 5 I recorded. I usually start with a 4 bar click, so you can tell right from the beginning that it is starting at a different time. I know I could jut nudge the tracks but, what is the point of using the sync if I will have to do that evertime. Any info will be greatly appreciated. Thanks in advance.
Re: Triton and Digi002 Midi Time Sync Problem
how do you have your midi hooked up?
i have mine slaved like you but i do it like this: go 4 out of triton to pts then use the button on the transport in protools 'wait for note" set the triton to external control in the global mode then, when you want to record, press play on the triton (the 1.00.00 will turn to 1.00.---) then hit record/play on the computer and you are in biz |
Yes I have it slaved to Protools and set to external control. I will try the wait for note function when I get home. I can rember though trying to hit play on the triton before with this setup and nothing would happen. I will try it though. Thanks for the help.
Sync to Korg Triton and Midi Tempo Change | www.mradlai.com | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-15-2006 04:44 AM |
Sync triton to PTLE Digi002 | Cayotic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-06-2005 09:41 PM |
.........digi002 and triton not linking up...midi. | woodbeatz | Tips & Tricks | 1 | 02-19-2004 06:31 AM |
Digi002 and Midi Sync Problem w/ MPC2000 in PT 6.1 | CHASE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-03-2003 06:03 PM |
Sync Processor's Tremolo to Midi Time Sync via Interface | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-01-2000 12:08 AM |
