Re: MTRX hookup question, Dante vs Digilink
If you want digital system audio into the MTRX and you’re using a Mac Pro you can run an optical cable from the headphone jack of the Mac into the optical input of the MTRX. This can then be routed into Pro Tools through DADMan and also assigned as a selectable source for monitoring.
Ah, I didn't realize the Line Out on the Mac Pro was a Mini Toslink jack, thanks. Not sure about the headphone jack, but at least the Line Out is.
Does this also mean that Pro Tools needs to be open with the correct routing for this to work, and that if I want to play system audio without Pro Tools open, it's not possible? Thanks.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
“Line Out”. Right. I was thinking about an older MacBook Pro having only one jack but Mac Pro has two.
How is your monitoring setup? With the DADMan application running you won’t need to have Pro Tools running to hear system audio. It will just need to be setup as a a source when you setup your monitoring profile in DADMan. The MATRX/DADMan serves as its own router for any set of inputs and outputs. Sent from my iPhone using Tapatalk |
That's great to know that DADMan will handle that without Pro Tools, thanks for the info. I don't have the setup yet, just going through options before I place the order.
You have optical MADI but you do not have toslink/adat optical on the MTRX.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#16
Indeed. I stand corrected. I thought the optional optical I/O card would handle TOSLINK.
As an alternative one could use a TOSLINK to AES/EBU converter into the MTRX. Sent from my iPhone using Tapatalk |
#17
I do this for one set of the MTRX's in-built AES/EBU with an RME ADI-192 converter. Bonus is it adds sample rate independence to the built-in AES for those connections going through the RME (there is no auto SRC on the MTRX AES inputs built-in -- only on the add-in AES card.) That may not seem like a big deal but it allows system sounds to be at any sample rate and not be forced to follow the MTRX/Pro Tools session current sample rate. (ie, I can play back a 96kHz file from the computer in RX7 while Pro Tools is open and locked to a 44.1k session)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 01-01-2019 at 10:28 AM. Reason: typo |
#18
I was planning on going Mac Toslink out to AES on the MTRX, but not looking for another rack-size box just for conversion. So far can't find any smaller options.
If a standard converter without conversion is used, does it mean that iTunes or 44.1K system audio would play back at a different pitch when feeding a 48K PT session?
#19
Think of it like a standalone box that happens to have mini digilink as one if it’s inputs. It’s totally independent of Pro Tools.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#20
Thanks, just placed the MTRX order yesterday, should receive it later this week. Looking forward to trying out some of these hookup options.
MTRX Dante latency stuck at 1ms | LukeHoward | Pro Tools | MTRX & MTRX Studio | 1 | 02-19-2018 11:13 PM |
MTRX Sync Dante and Video | laki | Pro Tools | MTRX & MTRX Studio | 10 | 12-05-2017 02:26 AM |
HD Native with 2 blue interfaces hookup question | Justin1524 | Pro Tools HDX & HD Native Systems (Mac) | 5 | 09-03-2013 09:49 AM |
Digi 002 Hookup Question | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-29-2004 09:04 AM |
Dumb Hardware Verb Hookup Question | COCO | Tips & Tricks | 2 | 02-08-2001 07:19 AM |
