Old 05-24-2018, 12:33 AM
bektolio's Avatar
bektolio bektolio is offline
Default Re: Eleven rack I/O
The driver was installed the iMac wasn’t allowing an extension of it. Apple support had to escalate it to engineering because we couldn’t fix it with screen share.
iMac - macOS High Sierra Version 10.13.4 - 32gb Ram - 1 TB SSD - I7 3.6 GHz
Old 05-24-2018, 12:41 AM
The driver *is* the kernel extension (kext), it does not have extensions. The kext is copied to the extensions folder but blocked from loading into the kernel by the macOS security. Until all that is done the driver is not installed (into the kernel), and so not working at all, hence my comment you never had the driver installed.... that should have been caught early on when you could not select it in the playback engine.
Again you seem to be all over this from different directions so I'm going to leave it with you.
Old 05-24-2018, 12:44 AM
bektolio's Avatar
Yeah it just wouldn’t allow it. I’ll let apple engineering figure it out and I’ll wait. Thanks for the support!
Old 05-24-2018, 07:07 AM
bektolio's Avatar
I figured it out on my own. After reading several threads I noticed the problem not allowing me to click “allow” in security was caused by me running EUControl. It acted as a third party mouse. I quit EUControl re installed the eleven rack driver clicked allow and it works perfect in pro tools now.
Old 05-24-2018, 10:09 AM
Excellent. And thanks for posting the fix to help others.
Hopefully you now are set. I would go back to getting a prerecorded audio track working just playing back into headphones, then recording the dry mic with monitoring through Pro Tools no rig anything involved, and especially not trying to hear the mic through the rig as you were before (Pro tools will mute local/hardware monitoring when a session is using the Eleven Rack so you can't locally monitor like that anyhow.).
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Eleven Rack and Cubase Eleven Rig L/R input NOT WORKING !!! quebecguitare Eleven Rack 1 09-01-2015 11:40 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
