Old 09-30-1999, 01:48 AM
JACEK GAWLOWSKI JACEK GAWLOWSKI is offline
Default How much memory for DAE and PT?
I have PT 4.3.1,d24,mix farm and 2DSP farms in my 9600/300/192mb.I also have following plug-ins:Waves Gold bundle,Pro FX bundle,MDT,Lexiverb,TC Megareverb,Hyperprism,TC Tools,Auto Tune,Amp Farm.I use my MLCD quite often and ocassionally Logic Audio 4.0.
How many mb should I assign to DAE and PT for the best Pro Tools performance with 192mb available in my computer?
Old 09-30-1999, 04:39 AM
WGM WGM is offline
Default Re: How much memory for DAE and PT?
PT 45MB
DAE 50MB
Logic 30-50MB
hope this helps
grey
www.soundwerx.com
Thanks
Grey
Post Supervisor
www.soundwerx.com
Old 10-05-1999, 04:26 AM
smack smack is offline
You know there´s a minimum/maximum field.
what should they be on?
Mats
Old 10-05-1999, 10:41 AM
Techsupt2 Techsupt2 is offline
smack
The minimum memory setting should be left at it's default. If you've changed this type the number 0 in the minimum field and press return. This will default the minimum memory setting.
Pro Tools preferred (maximum?) memory should be set to @35-45MB and DAE preferred should be at @40-50MB. If your using Waves plug-ins increase this a little more.
Brad
Kontakt Memory Server (KMS) Could not start MemoryServer. Memory Extension will be... John_Toolbox Virtual Instruments 5 12-29-2011 10:03 AM
MEMORY ERROR MESSAGES- Strange memory loss hwill2008 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-23-2010 08:14 AM
Memory is Low? Quit and Allocate more memory to PT Unite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2004 05:38 PM
Will PC2700 memory work in PC2100 memory slot? dfusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-08-2004 09:30 AM
Promting lack of memory on PC with adequate memory! Any tips? will22 Digidesign Hardware & Software 12 09-20-2001 08:36 AM
