Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 02-26-2020, 07:38 AM
ouibjamn ouibjamn is offline
Default Set default audio output path for new tracks
I've looked for a solution for setting a default audio output path for new tracks using I/O setup, but still can't get it to work. I always use Analog 1-2, S/PDIF L-R(Stereo) as my output, but every time I create a new track it defaults to 1-2 Stereo and I have to change it. I can't seem to get the default changed in I/O settings.
Old 02-26-2020, 07:45 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Set default audio output path for new tracks
Create a buss -say- OUT and map your preferred output to it. Then check that you have your OUT selected on Default Output Bus
Janne
Old 02-26-2020, 10:14 AM
JFreak, that totally worked. Thank you! Of course, it's just applied to the session I'm in. To make this global in the future, I suppose I have to import these I/O sessions into new templates?
How to select all "Audio Output Path Selector biuttons? briaboy Pro Tools 2018 2 04-09-2019 08:14 AM
[BUG for years]: PT ignores default output path when opening AAF/OMFs Frank Kruse Post - Surround - Video 2 03-21-2013 11:28 AM
Default Output for Tracks Imported from AAF Chief Technician macOS 0 09-13-2012 11:25 AM
Mic/Line 1 and Output 1-2 not showing up in audio input path selector gelianamrie Windows 4 08-02-2012 04:29 PM
Parallel FX - Send vs audio output path abt Pro Tools 10 6 03-08-2012 06:13 AM
