  #31
Old 10-03-2018, 05:24 PM
jacko's Avatar
jacko jacko is offline
Default Re: Youlean Loudness Meter 2 - FREE and PRO
Originally Posted by PhiBee View Post
Ok. Under PT 10.3.10 and macos 10.8.5, doesn’t work very well . Install ok, insert the plugin ok, but when using it ...
Have a look
https://share.icloud.com/photos/0OUe...tiers_Centraux
I have the same thing.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #32
Old 10-07-2018, 02:24 PM
Youlean Youlean is offline
Default Re: Youlean Loudness Meter 2 BETA - Free
Thanks! What happens if you turn off auto reset button? (button beside red X)
  #33
Old 10-09-2018, 01:02 AM
PhiBee's Avatar
PhiBee PhiBee is offline
I made a few more test under PT10. With or without auto reset, same issu. Also tested with different view/size.
WIP house Prod - home studio
iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61
STUDIO PRO Post-prod
MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic.
  #34
Old 10-11-2018, 12:19 PM
jacko's Avatar
The behaviour changes slightly but doesn't solve the issue. Also the readings are off by several dB. Other meters show values around -8 LUFS and on the same material in Pro Tools 10 HD Youlean Meter show -26 LUFS or so...
Let me know how I can help with the testing. :)
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #35
Old 10-19-2018, 09:17 AM
Thank you very much!
Sorry about the late reply. I will need to download PT 10 and take a look. I will let you know if I need the help.
  #36
Old 01-21-2019, 05:41 PM
jacko's Avatar
Any progress with getting this to work with 10?
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #37
Old 01-30-2019, 08:02 AM
I was not able to install PT 10.
EDIT: I pushed an update that should fix the PT 10 issues. Please try the latest version!
  #38
Old 08-22-2019, 10:47 AM
Matthew Steel Matthew Steel is offline
I wanted to try this plugin, but ProTools crashes on startup when the plugin is installed.
This is with ProTools HD 10.3.10 running on an HDX card under MacOS 10.7.5. It sounds like some people have had at least some success with this. Anything I should try?
  #39
Old 08-25-2019, 12:44 PM
Hey Matthew,
Try downloading the V2.1.1: https://youlean.co/wp-content/upload....1.1-macOS.zip
  #40
Old 11-01-2019, 05:27 AM
Hey Matthew,
Finally got back to trying this and that version works. Thanks.
[IMG] code is Off
WLM Plus Loudness Meter CL_Audios General Discussion 0 07-13-2014 08:49 AM
WLM loudness meter, need help. nossnevs Post - Surround - Video 5 03-09-2012 01:56 AM
How to set my Loudness Meter.... kd_special Post - Surround - Video 13 02-08-2012 01:41 AM
loudness meter, free plug ins, thank you Avid nossnevs Pro Tools 10 5 01-24-2012 12:17 PM
New loudness meter TC LM5 nucelar Post - Surround - Video 6 01-24-2008 02:50 AM
