PT Summing Stereo Tracks to Mono - differences between PT10 and PT12
I have a really bothering issue regarding compatibility with PT10 sessions opened in PT12. I don't know if any of you have encountered the same problem. Here is was I finally wrote to Avid support after running a lot of tests: Quote:
Thanks, JP. |
Re: PT Summing Stereo Tracks to Mono - differences between PT10 and PT12
Go to prefs set-up : it looks like you have a different meter type in PT12, so change it to Pro Tools Classic metering, and see if that changes your results.
Sent from my iPhone using Tapatalk |
I have the same results with other dBFS scale metering in Pro Tools as well as in metering plugins. I put the linear ones in PT12 so that everybody could read the numbers better than with the classic PT meters on the screenshots.
Anyway, the problem is just audible as it wrecks PT10 sessions that use this kind of summing when they are opened in PT12 (MS encode/decode routing especially). I have one friend who just tried this in his PT12-HD, same issue, no clue neither. |
Ok, it's a PT12 bug that was at least reported to Avid in November 2015. It's crazy that they let a bug that affects the audio routing (just that...) for so long. What's wrong with Avid?
Read the last post: http://duc.avid.com/showthread.php?t=372073 |
I have news from AVID about the summing bug in PT12. It seems that a simple text file placed at the root folder can change the summing of PT12 and that would be the patch! Interesting. Furthermore, they ask me to send a non disclosure contract that is pretty heavy to get that patch. I really don't like how AVID manages its customers. Damn, it's a bug that was very difficult to solve in the first messages, now it's a simple txt patch but I'm allowed to have it if I sign a form that last 3 years on several points that prevent me to investigate why their software (which I pay hard money for) is buggy. Crazy...
What do you think about it? Have any of you signed a non disclosure contract in order to have a PT that works? --- > Entered on: 4/12/2017 5:22 PM Entered by: Rajiv Arora Hi JP, A fix has been developed and is waiting to be implemented in the next days, please send me a signed copy of the attached Non Disclosure Agreement in order to provide you with the solution (including a beta build of Pro Tools 12.8) once it becomes available. Kind regards, Rajiv > Entered on: 4/17/2017 8:31 PM Entered by: Customer ( Integration) Hi, thanks for the information! Can I wait until it is part of the next official release (and what is its due date)? I don't especially want to have to install a PT beta version and work with it... Let me know. Best regards, JP. > Entered on: 4/18/2017 9:19 AM Entered by: Rajiv Arora Hi JP, Yes, if you prefer you can wait until 12.8 is available, however I can't provide a specific release date. The solution that has been developed is not built-in in Pro Tools yet, but comes in the form of a "DigiOption" file, which is a .txt file that you must put in the same folder containing Pro Tools (usually the Applications folder). In order to provide you with the DigiOption file that will automatically change the summing coefficients in Pro Tools I will still need a signed copy of the NDA, which I am attaching to this mail. Kind regards, Rajiv > Entered on: 5/2/2017 4:19 PM Entered by: Rajiv Arora Hi JP, I have still not received a signed copy of the NDA document, please send it to me at your earliest convenience in order to be able to provide you with the file that will adjust the summing coefficients in Pro Tools 12.8. Kind regards, Rajiv --- |
That looks like they are giving you access to the Beta Version. An NDA is standard procedure so you don't go leaking any new features to the world before they want them known.
^^ what he said... either sign & get, or don't and wait. this is the way software development works.
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
Unless the text file can only be used with PT 12.8 there is no reason for him to want a beta version of the software. It's a simple change to a config file. There seems to be a communication issue here.
Also, IMO the new configuration should be the default and should be part of the PT 12.8 release, or at the very least be well documented so people can make the change themselves. Breaking old projects is not desirable. |
But... I can have the text file if I sign a NDA stating among other things that I can't speak about a lot of things about PT for 3 years. It's very disturbing. I worked 10 years in databases management system development in the 90s and no, it's not the way software development works. When a bug is reported and it's impacting a core feature, you issue a patch for all users. They have a buggy audio core, they have eventually found the time to solve it by placing a txt configuration file in the app folder and they don't release it to all PT users??? Why? Their audio engine doesn't make a voltage addition properly, it seems not to bother them since 1,5 year, they finally have a patch that seems simple to deploy but no, they will give it only to me and if I sign a NDA that would btw forbid me to explain the solution to anyone concerned by this bug. It's crazy. Not so crazy if they are not sure about the effect of this simple fix on the other PT functionalities. But what don't they get when I tell them that I actually work with PT? I can't afford to run a buggy PT daily, I have sufficient thing to do other than reporting any other bugs the patch would create. Or do they search people to beta test PT12.8? Then, I'll be fine with the NDA but they are nor clear and I don't want to debug their next version just for fun on my work time. I mean, it's not like we pay $300 per year to have a software that just... works. |
Perhaps the fix is incorporated into 12.8 and not earlier versions.
So even if you have access to the .txt file it won't do anything in earlier versions. I suspect they want you to test the fix hence the beta version. Sign the NDA, have direct input into the development of the product and be happy. Mark |
Change a track from mono to stereo in PT12 | jamestr12 | Pro Tools 12 | 11 | 04-14-2017 05:13 PM |
Only mono and stereo tracks supported, some tracks have been dropped | cowfeet | macOS | 1 | 03-21-2012 07:16 PM |
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
Summing a stereo track to mono | scadh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-03-2010 02:16 PM |
How many Megs does a 4 minute song with maybe 3 stereo tracks/13 mono tracks take up? | Sergeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-04-2002 02:31 PM |
