#61
Re: Fine breakpoint adjustment change in 12.6 = Showstopper
I prefer the old way too. Definitely need a Preference that toggles the old and new behavior.
Anyone put this on IdeaScale yet? And this thread should definitely be a Sticky.
#62
Have you tried this using the Smart Tool? Have a look brotha Steve. It's Ctrl+Click, which brings on other issues you'll notice, including the omission of the new grid toggle in slip mode. Also, doing the main discussed action using the smart tool now requires this new clunky and quirky sequence: Ctrl > Click > Shift+Alt > Drag It's broken, messed up, and just not well thought out. Certainly not an improvement. But wait, there's more... Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#63
I do not use the smart tool so I can't comment on breakpoints with it. I will have a look at it though when I get time. But to create breakpoints, I have just clicked on the line wherever I wanted it. All in all for me, these changes have not slowed me down any. In some areas they have actually sped me up and having unity across the modes is a nice change. But they did require a shift in muscle memory.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#64
So what's the solution?
I think we're at the point where a majority of the pros and cons have been put forth. The other related issues I've seen are insignificant to really bother looking at. It's up to Avid to decide at this point. Shane
#65
A preference.
#66
New behavior is horrible.
Creating volume nodes with cmd (grid mode to avoid grid confinement) snaps the node to a grid line upon insertion. After that it works as expected—releasing and again holding cmd allows horizontal moment in between grid—but the entire behavior is a significant digression to workflow. |
#67
Preference.
#68
+1
#69
#70
You have to hold some sort of a modifer with the smart tool as it does not "react" to the "volume" line, it will be the selector tool for instance if you are not over top of a clip. This is the nature of the smart tool. You can create a breakpoint holding cntrl or with cntrl-shift. Then it works from there just like it does when you are not using the smart tool. You can create a breakpoint holding cntrl-shft and just start moving it after you create it without letting off. Everything is working correctly as intended. I don't see Avid changing it back nor adding a preference to change it back. I think its just a matter of everyone giving it a few minutes and just go for it and give it a bit of time to set in to muscle memory. I was absolutely not affected by it after a day. Everything works as they intended, its just a change in the modifiers you hold.
Fine Fader Adjustment On iPad? | producedbyriot | Avid S1, S3, Dock and Control App | 4 | 09-10-2016 01:00 PM |
Fine Adjustment on AAX seems to be Broken? | Neil Pickles | AAX Plug-ins | 4 | 06-07-2013 01:39 PM |
fine adjustment of breakpoints not working | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-03-2010 06:42 AM |
Fine volume adjustment | gbours | Pro Tools TDM Systems (Mac) | 3 | 05-02-2006 07:23 PM |
Strip Silence and Fine Adjustment... Still a bug? | SimpleNatureSpirit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-21-2004 11:22 PM |
