#21
Re: Pro Tools not recognizing iLok
#22
#23
Make sure the iLok is on a USB 2.0 port - known issue. No USB 2.0 ports - get a USB 2.0 hub.
Cheers,
#24
I still have the interface software installed, I'll remove it and see it it helps. The ilok problem just started happening today after a whole month working without issue. It only ever happens on the laptop, nowhere else, so maybe it's the RME software after all. I'll check it out. EDIT: Ok that was weird. I uninstalled the RME software, restarted and now pro tools it's loading up correctly. I hope it was not random and we could find a cause for the problem. I followed this thread for instructions on what to delete. It's not 100% accurate but the file names are similar. https://www.forum.rme-audio.de/viewtopic.php?id=9233 |
#25
OP here. Still having the problem. Sometimes unplug/plugging the iLok will work, sometimes not. Very frustrating.
Mid-2014 15" MBP Retina 2.8GHz Intel Core i7, 16GB DDR3, OSX 10.10.5, PT11.3.1 003 Rack Factory. |
#26
Do you have USB3 or USB2 ports? It's a known issue that the iLok2 doesn't get along with USB3 ports. Get a powered USB2 hub and use that between the Ilok2 and computer.
#27
I have this exact problem. I have to reinsert my ilok a few times before protools recognises it. Once it recognises it I have no problems after that. I've started using a powered USB hub in my studio and haven't once had a problem with it since.
#28
SOLVED!
Had the same issue. Found it was a problem with the driver signature of the ilok which seemed to be caused by the licence manager software. 1. Re-boot system and tap F8 on start up 2. Select the option "Disable Driver Signature Enforcement” 3. Continue boot up as normal after that and in the ilok license manager try to activate whatever current licenses you have onto your ilok stick. 4. Once done then uninstall the ilok manager software and protools should just get the validation straight form the ilok stick without having to go through the license software. 5. Done. *If you don't want to delete the software then you can follow steps 1 an 2 but you will have to do them on every start up which is a bit annoying. Hope it helps. |
#29
Sad (good?) to see others having this iLok that gets recognized one day and not the next. I figured I had an issue because I've got a USB hub with the iLok and other USB things are plugged into. I've heard the hub is a problem, but until this iLok issue, it's never been a problem. Then all of a sudden, my mouse wouldn't get recognized. I'm wondering if an AAE -9013 error couldn't also be prompted by this same issue?
Sorry to ramble here, richrdC |
#30
I did have a problem with the iLok not being recognized one time. All it took was to unplug and replug-in the iLok and all was well. Sometimes connections go bad all on their own without anything being moved due to humidity or such. |
Not recognizing my Ilok | patrickj75 | General Discussion | 2 | 11-05-2012 02:14 PM |
[HELP] Pro Tools not recognizing licenses on Ilok | dsdaniels | Windows | 3 | 10-27-2011 01:27 PM |
SC48 not recognizing iLok | vlepore | VENUE Live Sound Systems | 4 | 10-03-2010 01:37 PM |
BF Tel-Ray Delay 8.0.0 not recognizing iLok auth | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-02-2009 12:45 PM |
PT not recognizing license on iLok | cueball73 | Pro Tools M-Powered (Mac) | 4 | 01-23-2009 09:38 AM |
