Old 12-10-2019, 08:37 PM
mophilly mophilly is offline
Default Pro Tools in virtual machine
Has anyone attempted or succeeded in run Pro Tools in a virtual machine?
I upgraded my iMac to Catalina (oops). Downgrading to High Sierra or Mojave sounds like an exercise in frustration due to other apps that were updated as well.
I have used VMware Fusion for a lot things but not a DAW. So I wonder: can I get decent performance running Pro Tools in a vm?
Old 12-10-2019, 10:11 PM
Sardi Sardi is offline
Default Re: Pro Tools in virtual machine
Yeah I wouldn’t do that. Pro Tools is a PITA on a well configured system. I can only imagine it being a bag of hurt in a VM.
I take it you don’t have a backup/clone of your system?
If not, I’d start again and build a new boot drive and chalk it up to lesson learnt. Backups are handy and get you out of jams like this.
Best of luck.
Old 12-11-2019, 07:39 AM
Thank you for comments.
In this case, I discovered that the backup process had been disabled nearly a year ago, when the hard drive was replaced with an SSD. I am generally more on top of this sort of thing but failed for this system.
Another suggestion offered is to create a new boot partition, and install High Sierra in that. I am looking into that. A VM would be far easier in some ways but I take your advice.
Old 12-11-2019, 08:19 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Alt boot build and back to it.
My2cents
Old 12-11-2019, 08:37 AM
nedorama nedorama is offline
Format external drive as Mojave and run Pro tools off that as your startup drive.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Old 12-11-2019, 09:51 AM
Suggestion:
When you get things back up and running buy Carbon Copy Cloner, an external hard drive, and make regular backups of your system. It'll save your butt in cases like this. Don't use Time Machine for backups. And power down that external drive when you're done making your backup.
For reasons that Sardi mentioned a VM is a nightmare. Don't do it. Or you could use Bootcamp and run PT in Windows.
Jack
QAPLA!
Old 12-11-2019, 12:18 PM
I have a 2 TB G-Drive on the way. I have not used Carbon Copy Cloner for years but it does have a good reputation. I was using time machine for the easy stuff and a NAS for project archives.
This morning a colleague suggested I use the g-drive to create a bootable disk image of the complete current system on the g-drive. Once verified that the disk image is bootable and correct, reconfigure the iMac primary drive with some malice.
Old 12-12-2019, 06:30 PM
That is a very compelling suggestion. Thanks!
Pro Tools 12.8 and Virtual Drum Machine. foza1000 Getting Started 4 08-06-2017 04:34 PM
Virtual Tape Machine lydhagen Pro Tools HDX & HD Native Systems (Mac) 2 08-01-2012 07:53 AM
Mac as a virtual machine in a PC jcolagross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-17-2010 12:58 PM
drum machine (not virtual) w pt8? mdo9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-18-2009 09:31 AM
virtual drum machine boombatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-15-2005 12:33 PM
