Tips on looping part of a song?
Hey guys,
trying to loop part of a song but it's hard for me to make my separation just right. Get a click or something in there each time i try and it is starting to get a little frustrating. I believe I am making my separations when the wave form is passing zero all the way zoomed in. Any tips on how you guys do this? I feel it should be very easy but for some reason I am having a hard time. Thank you! -John |
Re: Tips on looping part of a song?
Hey John... use "Tab to Transients" to select the "Earliest Transient" in your multi Track selection, both for your "In Separation" and your "Out Seperation".
Then, when you've selected the perfect loop point (You can make your selection and audition how it's going to sound, by puting Pro-Tools transport in Loop Playback) And if it's really good, accept for a "Little pop" you're ok - Stop Playback - Make your selection - Cmd+D (To duplicate the loop the number of times you want it to appear in the time line) **TIP** If you want the rest of the song to be "Pushed back in the timelie AFTEr the loop, do the Cmd+D in "Shuffle Mode - Highlight the entire track (Cmd+A) - Cmd+F to open Fade dialog - Set the Fade dialog, to create a 5ms Fade at every edit (This will get rid of the loop "pop's") Good luck.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
ah the fade is exactly what i was looking for. thanks so much for the tip. do you normally cross fade at the edits?
Yep - almost always
Seriously great instructions. Tab to transients and Cross Fading made me able to do this loop in 60 seconds when i was working on it for over an hour before.
Glad it worked out for you... happy Looping
Help: selecting part of a song and create a loop | cheopsnet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-29-2010 12:09 PM |
How do you Change the tempo to part of a song using Elastic Audio? | jtknight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-17-2009 09:49 AM |
How to copy one song out of a multi song session? | Kevin Mowry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-14-2007 11:36 AM |
Two part ? Track placement & song tempo | 69flavor69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-26-2004 06:39 PM |
Copy a song section to another part of the arrangement? | 1511 | Tips & Tricks | 4 | 10-07-2002 09:43 PM |
