Old 03-16-2011, 03:48 AM
cary chilton cary chilton is offline
Default Can you run 2-3 mbox2's at the same time?
With a mbp and its 3 usb's - could you technically run 6 mbox2's in one sessions for 6 audio inputs in one session?
Old 03-16-2011, 03:53 AM
Dism Dism is offline
Default Re: Can you run 2-3 mbox2's at the same time?
Technically, with PT9.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 03-16-2011, 04:51 AM
BBass BBass is offline
Unfortunately it won't work, Avid's 00 series or Mbox hardware does not support Aggregate I/O.
Old 03-16-2011, 06:33 AM
JazzyJ JazzyJ is offline
You could make use of the SPDIF which would give another 2 tracks.
If you got an Edirol M-10MX M10MX MX 10 Channel Analog Battery Mixer for $69
Then you'd have a lot more inputs although you'd still only have an extra two outputs.
Edirol M-10MX 10-Channel Battery Powered Mixer Features:
Compact and portable, perfect for mobile/field use
Wide range of analog inputs and outputs, including two TRS 1/4" output jacks
24-bit/96kHz S/PDIF coaxial and optical outputs
Battery or AC power (AC adaptor included, no batteries included)
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 03-16-2011, 09:14 AM
HD2 HD2 is offline
From what I understand the 002 and 003 series does not support aggregate but the mBox does.
Old 03-16-2011, 10:50 AM
Not true.
002/003 and HD gear does not support Aggregate I/O, but the MBox series does.
D
Old 03-16-2011, 01:32 PM
derFunkenstein derFunkenstein is offline
You'd also be recording all those inputs on just 2 tracks at most. I don't think this is something you'd want to do. If I have 4 inputs, I want 4 tracks so I can play with balance, though I guess I'm not everyone.
External Pre's and Mbox2's JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-30-2012 01:53 AM
Clip Gain won’t update in real time during playback on Elastic Time tracks yanos macOS 0 06-03-2012 03:48 PM
Do all Mbox2's have same preamps? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-07-2011 10:55 AM
Can I use 2 mbox2's at once mootsland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-11-2010 07:51 PM
Mbox2's 6.8.1 (((((( S.O.S.))))))) Eric9v 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-06-2005 07:44 PM
