Old 03-01-2011, 09:44 AM
cary chilton cary chilton is offline
Default 15 or 17 inch New Macbook Pro?
I am buying the new MBP but which one??? I know that only the 17inch has the PCMCIA express port and that is necessary for UAD solo. However the UAD DUO unit looks pretty cool and the MBP 15 inch would it just fine.
So what advantages are there with the 17 inch MBP besides the express slot?
Old 03-01-2011, 09:56 AM
getz76 getz76 is offline
Default Re: 15 or 17 inch New Macbook Pro?
About 2 inches, one way or the other.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 03-01-2011, 11:09 AM
that's it huh? lol well and another usb port
Old 03-01-2011, 01:42 PM
WinTaper WinTaper is offline
If you're using it to capture and then plan on working on another machine - go with the 15. If you plan on working extensively on the macbook - go for the 17. Realistically the only difference is the larger screen - but if you're using it a lot thats a BIG difference.
I use my MBP 15 to capture remote sessions - but I transfer those to my MacPro do work on.
-Dan
Pro Tools 11.1.2 | Mac OSX 10.9.2
RME Ray-DAT | SSL Alpha-Link AX
Intel Core i7 990X @ 3.60GHz
Gigabyte EX58-UD5 rev 1.0
Old 03-01-2011, 02:13 PM
jwilkers jwilkers is offline
I have a 15 but bought the large external monitor. It's wonderful.
Old 03-02-2011, 03:45 AM
LanceK LanceK is offline
However having the express card port is a big plus for future expansion. I got an ESATA card and a MADI card for mine.
Old 03-02-2011, 04:52 AM
DUlrich DUlrich is offline
Hope you dont mind me popping in your thread.. I too am planning on picking up a Macbook Pro and leaning towards the 15 ( will just add a cinema disply in the future) but my question leans towards what Hard drive.. are the SSDs good to go? I am already planning on an external firewire drive for my audio recordings....
Thanks
Dave
Old 03-02-2011, 05:08 AM
I've recorded 32 tracks @ 48K/24b without problem on the internal 7200rpm drive. As I said - I don't work/mix on the MBP - just capture live with it.
The express card is a consideration in the 17" (my 15" has one - stupid move by Apple taking it out of the 15). But most things can be done firewire these days.
Old 03-16-2011, 03:46 AM
Hey, just a follow up. I ordered my 17 MBP today! Antiglare, 7200rpm 500 GB drive, iWork, 8GB RAM 2.3 GHz Quad and applecare. just under 3100 usd.
I read that the 15" run every bit as hot as the 17 or hotter. THe Express card slot was another consideration as well the extra USB ( for my ilok)
Here is something probably none of you know about that I learned from Craig at Sunset Sound Studios CA. SSD drives besides have a 30% failure rate also break down due bad sectors from regular overwriting new info... Apparently after 3-5 years the SSD's break down. Your 256GB SSD might only have 100 GB of functionality after 3 years!
Not a big deal if a 256 drive was 100 bucks ( and it likely will in 5 years time) but at 500 usd! I'll pass
Old 03-16-2011, 08:59 AM
HD2 HD2 is offline
And Craig at Sunset Sound Studios based his statistics on what? His personal experience with SSD drives at the studio? Or does he have a list of everyone that as purchased an SSD drive?
Or perhaps more than likely he read that on a blog somewhere and passed it on to you as fact, without doing any real research on it, just as you are doing here.
MacBook Pro 13 Inch is Dual Core smoothbassman macOS 5 02-11-2013 06:05 PM
MacBook 13 inch, i7, 2.9 ghz, 8gb JustGotPaid macOS 4 01-17-2013 11:03 AM
MacBook Pro 15-inch i7 with SSD on order...how to best install software? Guitarman002 macOS 4 12-12-2010 09:07 AM
Which is better? (New) MacBook Pro 15 inch or 17 inch Hookshot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 07-21-2009 09:07 PM
They're Here! MacBook Pro - 17-inch coolcat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-24-2006 02:20 PM
