Can converter errors cause waveform errors like ..
What happens if the A/D converter can't keep up with the recording, would it do this to the waveform?
<font class="small">Code:<hr /><pre> - - - - - - - - - - - - - - - - - </pre><hr /> heres the same waveform repaired in Soundforge with the pencil tool: <font class="small">Code:<hr /><pre> - - - - - - - - - - - - - - - </pre><hr /> I detect these errors in many files when scanning for errors in Soundforge (when using the find glitch tool and zooming in), Computer can do 32+11 in DaveC with no errors at 128 H/W buffer size. would using 3rd party A/D converter help in this situation? Note: don't confuse this waveform problem with improper use of crossfades or shuffling 2 seperate regions together without Zero crossing as these errors are found in contiguous non-stop .wav recordings. |
Re: Can converter errors cause waveform errors like ..
Looks like a clocking error.. which converter are you using, and how do you have it interfaced to Pro Tools?
If you're using an external device, do you have the sample rate in the the device set to the same sample rate as the Pro Tools session, do you have Pro Tools set to external clock, do you have the external device set to internal clock? Rail
Thanks for the quick response Rail
Then make sure that you're clocked to internal - if you already are.. then it's a hard drive issue.. check your DMA and IRQ stuff -- it'll be a write error. Turn off any cache or write behind stuff and see if it improves.
Rail
One more thing, Is it possible to disable this "write cache" with an external IEEE1394 drive using Oxford chipset?
this might be my only other option with this computer. |
I have a similar card - look at these pics which show how mine is set up and which driver I'm using.
http://www.railjonrogut.com/promise1.htm Rail
Open Explorer to look at your drives, select a drive and right click on it and select properties Click on the Hardware tab - select a drive in the list and press the button labeled Properties and select the Policies tab. There you can set the write caching, etc. Rail
Ah, those are Maxtor custom Promise drivers?
2.00.0.43 2.00.0.42 from promise.com dont have this option,. So from your screenshots it looks like you have write caching enabled for more stability, I would want to uncheck the box correct? I'll give em a try on the PTLE machine. |
You want to try changing the value(s) and seeing if the problem persists... I had originally turned this off, but had no problems with it on -- so left it on.
Experiment with the different settings and see if it's any better. Of course, you may just have a bad 002 power harness too... or a FireWire issue... which FireWire card do you have? Do you have the issue with FireWire drives? Rail
Waveform draw errors in PT9 | poly915 | macOS | 1 | 03-18-2011 12:04 PM |
many errors- fatal errors and 9060 error. Sandra report inlcuded.. | bradykrzemien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 09-16-2009 11:56 AM |
Creating DAE Objects/DAE Loaded!! errors errors HELP!!!!! | KasticK | Pro Tools M-Powered (Mac) | 2 | 10-20-2007 10:42 AM |
HW Buffer errors and Mass Confusion! 9093 Errors!! | guitarlancer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-08-2007 10:38 AM |
errors errors errors Please digi tech guys help me | dunkyj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-11-2005 01:19 PM |
