Old 05-05-2021, 12:46 PM
Danny_79 Danny_79 is offline
Default Confused by the Klangfreund LUFS meter
Hi! Anyone familiar with this one? Despite the help section, i don't really understand it. I am only interested in the LUFS and the true peak, so which one of all these meters should i look at? Wich one is the LUFS? Screenshot below. Thanx https://1drv.ms/u/s!AicUKOG8nZ_IhuN-gi2YR-8saQfZPA
Old 05-05-2021, 02:20 PM
Sonopolis Sonopolis is offline
Default Re: Confused by the Klangfreund LUFS meter
Guess you want to know the LUFS integrated long-term value. That's what he "I" stands for. The TP value is clearly shown above. However I don't know what the fader to the right and the "Adjust to" are doing in this meter,
Old 05-05-2021, 02:44 PM
To be honest i'm not sure...but i asked a mastering engineer what volume he wish the tracks to be in when i send them to him. And he said around -16 db LUFS and maximum -3 db true peak. I kinda wish the meter was more simple....i know there are some meters who says only "LUFS" and no further details But i guess it's the "I" i should focus on then?
Old 05-06-2021, 01:53 AM
crizdee's Avatar
crizdee crizdee is offline
There’s no need to send a track for mastering at -16 Lufs or -3db TP. That is nonsense! As long as the TP isn’t reaching -0 DBFS or peaking or hitting clip then everything is fine. Everyone is working with floating point bit rate now so absolutely no need to worry about levels or targets for pre masters. Just make a great mix and don’t send with any limiting exciters or wideners etc. If you’re using bus comp and EQ and you’re confident it’s doing a good job then that’s fine.
The ME can simply adjust the level to what ever they wants to work at
Unfortunately there’s too much hype around about levels and targets. Mostly on websites that want to sell you their plugins.
Chris
Producer, Engineer,
www.ukmastering.com
HTML code is On
LUFS meter and frequency coded waveforms jchan Pro Tools 2020 0 06-02-2020 11:42 PM
LUFS Metering in Pro Tools conorkelly Post - Surround - Video 11 01-24-2018 09:00 AM
Klangfreund LUFSMeter - not a valid 64 bit aax plugin samzilla AAX Plug-ins 3 06-03-2016 12:34 AM
Fastest way to get LUFS Wawili_Sound Tips & Tricks 2 07-14-2015 06:08 AM
Cheap lufs meter stereo only PhiBee Post - Surround - Video 1 07-14-2015 03:57 AM
