Old 03-27-2018, 10:39 PM
mikeyman's Avatar
mikeyman mikeyman is offline
Default What type of Plugin is it
How can I find out what type of Plugin i'm using AAX or Vst ect.Where in PT's 10 does it tell me...Thanks
Old 03-27-2018, 11:32 PM
BScout BScout is offline
Default Re: What type of Plugin is it
There is no VST in Pro Tools.
If you pop open the plugin you can see if it is AAX or AAX-DSP just under the "Bypass" button inside the open plugin. (also true for RTAS if since PT 10 is the overlap version)
Old 03-27-2018, 11:55 PM
TNM TNM is offline
are you using HD 10?
There is no VST in any version of pro tools whatsoever.
In PT 10 you can use rtas and 32 bit AAX.
I believe that was the last version that could also use TDM DSP with PT HD.
So if you are using HD hardware with DSP it's either native rtas, aax or DSP.
If you are using core audio or HD Native then it is either rtas or aax 32.
Rtas has been completely eliminated as of PT11 and upward, the only formats now are either AAX native 64 bit, or AAX dsp.
Does make it easier.. just one format for all, and either dsp or not.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX
Old 03-28-2018, 01:17 AM
mikeyman's Avatar
i'm using 10 native...Thanks guys
Old 03-28-2018, 04:38 AM
crizdee's Avatar
crizdee crizdee is offline
Very top left of the plugin... one small circle TDM or RTAS. two small circles AAX
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-28-2018, 12:09 PM
mikeyman's Avatar
thank you
HTML code is On
What plugin do you use for a telephone voice type of effect? DJ Hellfire Tips & Tricks 23 12-23-2008 07:05 AM
type then talk plugin blackaxe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-18-2005 08:54 PM
changing plugin type TDM > RTAS kraftrourke Pro Tools TDM Systems (Mac) 2 03-03-2004 01:12 AM
HELP ! ! PowerBook G4 error Type 3, Type 2 HELP ! ! Liquidtrek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-18-2002 06:28 PM
PT Mix 4.3.2 +Midi Playlists = Type 2 & Type 1 crashes Lewis Ross Pro Tools TDM Systems (Mac) 1 11-09-1999 07:03 PM
