Old 03-14-2018, 07:15 PM
mikeyman's Avatar
mikeyman mikeyman is offline
Default Softube Tape
anyone using Softube Tape with Pro tools 10 native 32bit windows 7 in the AAx format...thanks
Old 03-14-2018, 07:20 PM
BScout BScout is offline
Default Re: Softube Tape
All Softube plug-ins support both 32- and 64-bit hosts, although a 64-bit OS is required.
You can get a demo from them to see how it won't work.
Old 03-14-2018, 10:56 PM
mikeyman's Avatar
thanks
Old 03-26-2018, 07:42 AM
simon.a.billington simon.a.billington is offline
What’s everyone’s opinion of this?? I’ve been tempted by this one before.
Also loving the Drawmer and the new Weis plugins, hard to find these anywhere else.
Old 03-26-2018, 09:02 AM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
I can only give you my opinion Simon and I think it's a great plugin. It has earned a slot on either the drum-bus or the 2-bus of pretty much every mix I do.
On the 2-bus mostly Type A (Studer)@ 30Ips and maybe with the cross-talk set slightly above nominal.
On the drum-bus, anything goes! It pays to experiment with settings.
Softube's (Tube-Tech) CL 1B & Pultecs also get a lot of love here.
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
Old 04-07-2018, 08:09 PM
mikeyman's Avatar
I found that Softube TAPE sounds good but there is only one setting I can hear a difference and I read some other guy say the same thing.It is setting B with the saturation turned full up...You can hear it most in the bottom end .The other control are audible but the main tape setting for me is ''B''
Old 04-07-2018, 08:13 PM
amagras amagras is offline
Waves Q clone can be useful in those cases
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-08-2018, 01:21 AM
chrisdee's Avatar
chrisdee chrisdee is offline
I have the Softube tape plugin but it’s so slow to open it on my old system so i stopped using it. The Hornet tape plugin is much lighter. Very fast to start and very low cpu usage. Not as many controls but sounds great to my ears.
Old 04-10-2018, 04:14 PM
mikeyman's Avatar
I tried the Avid ''Lo-fi '' last night on my mix buss ,,it has a preset for tape saturation..Wow that really boost the mix
Old 04-10-2018, 08:36 PM
mikeyman's Avatar
I RENDERED SOME DRUM TRACKS WITH the softube TAPE plugin under the Audio Suite plug and I could see the change in the wave file on the bass drum mainly get bigger.Not sure if i'm going to buy it at 50$
HTML code is On
Avid Reel Tape Suite/Softube GC saptezsapte Buy & Sell 0 05-06-2017 11:59 PM
Tape One released : tape delay by Noise Makers Noise Makers AAX Plug-ins 4 01-05-2016 01:57 AM
Tape Emulation - Using Tape Delay to shape tone derker Eleven Rack 15 04-13-2011 09:10 AM
Reel Tape Saturation vs. Massey Tape Head? CalebB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2008 11:49 AM
tape or no tape?? opinions?? skeeters Pro Tools TDM Systems (Mac) 9 05-20-2003 02:10 PM
