Old 02-25-2011, 11:02 AM
eric22rr eric22rr is offline
Default Ozone 3 ALWAYS returns mono as RTAS
First of all, I'm asking Izotope tech support the same question, but I wanted to also ask it here in case others have experienced the same issue and have any advice.
I've spent hours trying to figure out why Ozone 3.15 RTAS makes my stereo signal mono in Pro Tools LE 8.0.4 in Mac OS 10.6.6. I have used Ozone many times, but I'm not sure if I had used it since upgrading to PT 8.0.4 a while back, so I don't know if there's a version compatibility issue that I didn't notice.
Whenever Ozone is engaged on a track, it makes the signal mono, even with all 6 of the modules bypassed. I first noticed this when I tried to use the stereo widening module, and realized that it didn't work -- this was also indicated by the fact that the vectorscope always indicates a mono signal, no matter what settings I use. I made sure that within channel ops, Ozone isn't set to create a mono signal. Either way, something is clearly wrong just based on the fact that by turning on Ozone as an RTAS plugin, even with all 6 modules turned off (for all intents and purposes, it should be 'bypassed' in this state) the signal still outputs mono. Doing an overall bypass to the plugin returns the signal to stereo. In other words, no matter what, Ozone returns a mono signal -- the other 5 modules (compressors, EQ, etc.) work fine, though.
I have all of the settings within Ozone and Pro Tools set correctly, and the versions of PT LE and Ozone 3 as stated above are the latest versions. It still doesn't work.
Any ideas?
Old 02-27-2011, 02:31 AM
JazzyJ JazzyJ is offline
Default Re: Ozone 3 ALWAYS returns mono as RTAS
Try Ozone 4 and it'll will probably be OK!
http://www.izotope.com/products/audio/ozone/
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 02-28-2011, 01:35 PM
I knew someone would say that!
Ozone outputs mono only, even on stereo track eric22rr The Drum Room 1 01-23-2011 07:36 AM
Mono or Stereo Returns spaceman Tips & Tricks 5 03-10-2009 04:01 PM
ozone 3.15 on masterfader gives mono output chicken 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-08-2008 11:57 PM
Ozone with wrapper?? or rtas- T-racks RTAS ???? Camilo Toledo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-14-2004 06:35 AM
RTAS mono to stereo-Plugin TCDet Pro Tools TDM Systems (Mac) 4 07-22-2003 07:09 AM
