Ram Limitation?
Is there a limit of accessable ram on an Mac like there is on a PC?
Re: Ram Limitation?
Yes but not in the same way...
4GB per process... So most plugins in PT run within the PT process, but some do not and can take advantage of additional ram.. (so I've been told) All the other system processes can each take advantage of up to 4gb as well.. At least thats the theory as far as I understand it..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: Ram Limitation?
So if I have 9GB RAM is each processor using a different bit of RAM?
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core 16 GB RAM Mountain Lion 10.8.5/El Capitan 10.11 Focusrite Saffire Pro 40 Ableton Live 10/Presonus Studio 3 |
Re: Ram Limitation?
OS's in general work the same way and set a limit of physical and virtual RAM that each process can access. Window's I believe is 2/2GB physical/virtual, and OS X I think its 4/4GB physical/virtual. So PT main app loads and get its 4/4. PT spins off processes each one get it own 4/4. Load plugs and etc they each get 4/4.
Being most our computers don't have boatloads of physical RAM so virtual/swap is used. That is why important to have a fast OS drive where swap resides. Also limiting what's on the main drive so all the I/O can go to handle OS, swap, and app. That is part of why Digi say record to a separate drive you're creating contention for IO if everything on one drive.
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
Re: Ram Limitation?
Re: Ram Limitation?
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
1st 32 i/o channel limitation? | vieris | Pro Tools 11 | 5 | 06-23-2013 11:09 AM |
Is this a windows limitation ? | jeam25 | Windows | 6 | 02-25-2013 11:53 AM |
Digibase bug or limitation? | JimLeb | Pro Tools TDM Systems (Mac) | 12 | 02-08-2010 07:14 PM |
Ram limitation. HELP !! | Allan Speers | Digidesign Hardware & Software | 4 | 12-10-2002 01:43 PM |
Direct I/O limitation | shadowbox | Pro Tools TDM Systems (Mac) | 3 | 03-02-2001 07:48 PM |
