Hearing Reverb AUX Track
Hello All.
I'm kind of new to Pro Tools and need some help. I'm in the process of doing a mix. I created an Stereo Aux Track where I have inserted a Reverb plug-in. I have all my audio tracks bussed out to the Stereo Aux Track. I would like to be able to just hear the Stereo Aux Track (to hear just the "Wet" signal) but when I "solo" the Aux track I don't hear anything. I know I'm missing something, so if someone could shed some light on the situation I would greatly appreciate it! Thanks in advance! |
Re: Hearing Reverb AUX Track
Solo the aux track and one or more of the audio tracks. You of course have to have something going to the reverb to hear the effect.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Thanks Park,
I tried that but I am hearing the Audio Track ("dry") combined with the Aux track. I just want to be able to listen to (audition) the "wet" signal from the Aux track. I hope this makes sense. Thanks! |
Apologies if i have misunderstood your problem but you should be using the sends on your audio tracks to feed signal to the stereo Reverb Aux.... that way if you click the 'pre' button on each of the audio sends going to the reverb Aux you will be able to then mute these audio tracks (thereby killing the dry main output signal) but still hear the "wet" signal that is going from their sends to the stereo Reverb Aux. Hope that makes sense. Have the reverb set to 100% and then use the reverb aux fader to choose how much reverb you want.
002R, PTLE 7.3, P'book G4, 1.5Ghz, OSX 10.4, 1 Gig Ram |
MacBook Air M1 (12.6) 8GB Ram Focusrite Scarlett |
Thanks Leadfinger,
You understood me perfectly. I do have it set up as you suggested. I can hear the reverb perfectly if I do as you suggest. The problem is that I have my audio sends set up as "post fader" which will give me a different level. Again, I don't know if I'm missing the obvious here. Many Thanks! |
it is not standard practice to listen to verb only
it is standard practice to listen to verb blended with source (so SOLO SAFE the aux track) the only way to do what you want is to make all of you sends pre fader instead of post
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Add one more stereo aux channel to your existing session. Set the input to an unused stereo bus and set the output to the main stereo out (1 & 2). Set the output of all tracks to the stereo bus that feeds your new aux instead of the main out. Whenever you want to hear only reverb, mute the new aux. Will this do what you want? Jeff_C |
Check out this thread just copy and paste it into your browser should help i was having similar probs
http://duc.digidesign.com/showflat.p...part=1#1134900 |
not hearing audio when RECORDING track (Acid Pro) | JoyMODE101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-28-2005 08:07 PM |
Hearing reverb while recording vocals | Semantick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-22-2004 06:55 AM |
Hearing a 9th track during recording | Smakrabit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-01-2004 08:56 PM |
problem hearing any track besides 1/2 - i'm new :( | romerom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-29-2003 11:11 AM |
Help with hearing Compression/Reverb/ etc while the vocalist is recording.... | Target Earth Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-01-2002 07:18 PM |
