  #31
Old 07-05-2015, 10:59 AM
Bob Thomas Bob Thomas is offline
Default Re: Error AAE -6101 in Pro Tools 12
I have ranged from 8 tracks to 24 tracks mainly sometimes a little more! Before I updated the OS recording was smooth had the SC on mid way buffer and PT on 128 I believe and it was running great and going for a solid 4 hour session! It isn't the capture going wrong and I'm sure it's nothing to do with it. I'm pretty convinced that it was the update from Yosemite 10.10.3 to 10.10.4 that did it considering it worked fine the day before 10.10.4 was released! I updated the Mac and then used PT probably 5 hours later and the problem started occurring!
  #32
Old 07-05-2015, 11:10 AM
Amack Amack is offline
I believe that you are going to have problems unless the SC and PT show the same Buffer Size!
  #33
Old 07-05-2015, 11:31 AM
When I set it up I didn't touch the buffer settings on either! I only changed them when the error started happening
  #34
Old 07-05-2015, 12:31 PM
Bob,
If both PT and SC don't show the same buffer size, PTs round trip (record) latency correction won't work properly. So, newly recorded tracks won't be properly synchronized with previously recorded tracks. You will also miss the beginning of some recordings if PTs buffer is larger than the SC's!
Amack
  #35
Old 07-05-2015, 12:41 PM
Right okay they should both be on the same! Before the update when PT was running there where no issues at all! And the error probably happened 10 times before I started to change the buffer sizes
  #36
Old 07-12-2016, 07:54 AM
GW GW is offline
Did you try SetUp/MIDI/MIDI Studio
...and setup multiple clock sources? If I use Pro Tools Aggregate I/O and (in my case) click both Avid002 and One + Glidecompesation - this problem seems to reduce...
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
  #37
Old 08-29-2016, 09:25 AM
GS-DK GS-DK is offline
WHY????? did I leave PT 10??? - The 6101 error is killing me in latest PT 12- it's all over the place. I have a 12 core MacPro 3.46 with lots of Ram - SSD disk - and a very trimmed system and still.....every once in a while I am asked to increase the buffer which can't go any higher. Please fix the problem, thanks.
  #38
Old 12-18-2016, 04:14 PM
Jegan210's Avatar
Jegan210 Jegan210 is offline
I've been working on this issue for a few days. I actually only received it when using Pro Tools Aggregate I/O when editing whilst travelling.
Hopefully this will be of use to some of you, but on 12.4, the issue for me seemed to be selecting "Minimize additional IO latency" under 'Playback Engine". As soon as I unchecked the box, the error vanished.
  #39
Old 12-18-2016, 04:23 PM
Yes - You are right. It solves the problem - Avid is working on the case (I have had several remote sesions and they are able to reproduce the problem) so something will show up.
The solution is to uncheck as you describe. I can still use my UAD interface then.
  #40
Old 07-29-2017, 02:26 PM
LarsC LarsC is offline
Just this one from April '17 on Avid page:
http://avid.force.com/pkb/articles/e...t-Disconnected
I haven't tried it. Could you please reply when you've tested it?
Pro Tools 11 AAE 6101 error Different solutions summing. S.O.S! Kipodag macOS 13 06-27-2015 08:51 AM
CPU error with Pro Tools 11 (AAW 6101) sandbar macOS 4 02-14-2015 02:43 AM
Pro Tools 11 Rcording error (AAE -6101 brenden80 Pro Tools 11 1 02-02-2015 04:52 PM
Pro Tools 11 - H/W Buffer Size Error AAE-6101 SterlingJ85 macOS 1 06-25-2014 04:39 PM
CPM Overload Error 6101 on Pro Tools LE v8 cmcclean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-25-2011 08:32 PM
