Still wondering what all think about Kontakt. Is it worth the money? Great soundset? Any compatibility issues with PT? ...............Anyone?!
this now. I should try it with my Project Mix......The only other problem I am having is getting any kind of multitimbral operation between the two. I recorded an EVP88 track and an Ultrabeat track and found both of the PT midi tracks were triggering both instruments in Mainstage. I admit after having Mainstage since last September I've never really dug deep into how it works. I'm gonna run off now and do try some more tests...... |
OK now I've figured out how to set all of this up and it works like a CHAMP! It took me about an hour of going through the Mainstage manual but I managed to configure it properly so multiple instruments can be routed separately and triggered independently.
First you have to setup a "controller" device for each PT midi track you plan on using in the layout screen. It is in here where you can select which midi interface and channel each controller can receive on. You simply set it for IAC Buss and channel 1,2 etc. Then you go into the Edit screen and select which instruments you want use and insert them into the channel strips. Each channel strip can be set to receive in the channels inspector on the lower left hand side. If you are running everything on the same interface,simply select your Digi driver as the audio driver, assign alternate outputs(3-4,5-6 whichever) and physically connect them from the alternate outputs to inputs 1-2 on your Digi interface with a pair of cables. Now you are all set. As JohnO stated, it's great that Digi allows multi-client functionality of their drivers now. You should now have an an audio VI rack to use with Pro Tools. If you want to print the tracks as audio, simply solo the instrument channel in Mainstage and record away. If you have multiple I/O patched,all the better you can print your Logic VI's to audio in PT. |
Really cool! So nice to have Logic's bazillion cool sounds with Pro Tools.
Can't make it multitimbral, right? Seems like only one can be played at a time. Just open another 'Concert' I suppose. Did you find a way to disable Mainstage from playing the direct MIDI keyboard input? I can't, but it doesn't affect the sound at all (no phasing), so who cares. Mainstage seems to 'see' the incoming MIDI from the IAC bus before it goes thru PT. Maybe I'm just too tired to figure it out. Really great to have this tho, thanks to all for figuring this out. The sounds in Logic and the way they are organized is great. They should sell Mainstage as an RTAS plugin. |
Actually, that's not the case. Since you have an Mbox 2, which is a CoreAudio-compliant device, it can allow CoreAudio to use the hardware even with Pro Tools open. If you do this with another Digi interface (like a 002 or 003), you can only have Pro Tools or the CAD running, not both.
bite out of the Reason market if they did this...or not!! I have figured out the multitimbral thing. You have to create multiple controllers in the Layout page(drag two or more of the keyboard icons above)Mainstage will support the use of multiple midi controllers. All you have to do is click on each one in the Layout page and assign the midi device/interface on the left hand side. Then open the Edit page and click on each instrument channel strip and assign the midi channel for each in the inspector on the left hand side. So if you have say, 4 midi tracks in PT, you would have to drag 4 separate keyboard icons into the black field above. Click on each one to assign each it's own midi port/channel. Then do the same in the Edit page for each of your 4 channel strips. My direct midi input goes: K2000 midi out>Project Mix midi in then I assign each midi track's input to the Project Mix>output to IAC buss>Mainstage. So really I'm playing into PT and then it's sending midi out the IAC buss into Mainstage. I found out you have to have "Midi thru" enabled in PT under "options" to pass signal through and you still have to Rec. enable the PT midi track. |
Actually, my HD rig couldn't do this either as I recall. I have to say, MBox2 Pro + MacPro 2 x 2.66 kills HD2 + G5 dual 2.7 for composing and scoring.
Re: Logic Rewired through PT?!
"I have to say the new PT 7 audio driver is great, allowing other apps to play at the same time as PT. iTunes, whatever, even when PT is open. Been waiting many years for that!"
How is that possible??? Pro tools uses a different audio driver than core audio when running pro tools |
Just figured out , how to stop "midi looping" in mainstage.
Go to the Environment page in Logic (command 8) Go to "Clicks and ports" Disconnect the iac bus "cable" Hey presto, no more looping in mainstage. Enjoy, Leggy :) |
Hosting 32-bit VIs in 64-bit Reaper Rewired to PT | Top Jimmy | Virtual Instruments | 9 | 12-19-2013 10:48 AM |
C8 not co-operating with rewired Live | clutch | ProControl, Control|24, Command|8 | 0 | 01-22-2006 02:00 AM |
C|8 and rewired apps | silverlode | ProControl, Control|24, Command|8 | 4 | 12-27-2004 07:23 AM |
can garageband be rewired | LL Lush | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-31-2004 08:05 AM |
reason rewired cant see | LL Lush | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2004 10:01 PM |
