Old 09-05-2009, 12:25 PM
Monty_python Monty_python is offline
Default Hitting Play or Record, blue stop button lights up... delay
WIN XP SP3 PT8
Hello, I've been dealing with this issue for a long time, it's not a consistent problem either and it doesn't matter if I have a large or small session to provoke it.
When I simply hit Play (or F12 to record), the green Play Button lights up but so does the Blue Stop button and the session will not play. To get around this I simply hit Play (spacebar) two more times, once to stop the current play command (which actually isn't playing, it seems to be in idle with both green and blue lights still lit), and again to actually get the session to play. It usually actually plays (or records) after I do this, some times I need to repeat the procedure a few times to get it going.
The computer doesn't crash and PT rarely freezes. I get around this pretty quickly, clients don't even notice because I do it so quickly. Is there a setting that is making this happen, a bug or bad work flow?
Thanks for your time!
-Monty
Old 09-05-2009, 01:23 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Hitting Play or Record, blue stop button lights up... delay
Lots of threads on this already. Supposedly fixed in 8.0.1. Make an Acronis Image and then update to 8.0.1 and try it out.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-05-2009, 01:39 PM
Thanks for the reply, sorry for the poor search skills. I'll wait until my important sessions are out of the way before upgrading in case something goes wrong.
Thanks you!
-Monty
Old 09-05-2009, 04:07 PM
TOM@METRO's Avatar
Thanks you!
-Monty
This is the reason for the image. You should do this regardless of the status of your sessions.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 09-05-2009, 04:21 PM
The Weed's Avatar
Tom,
It's amazing to me how people resist making an image or even contemplating the process. A producer friend of mine spent many, many months rolling his eyes at me every time I mentioned Acronis. He finally tried it and then asked me why he hadn't done it before as it saved his a**.
Cheers,
SonoBus
Old 09-05-2009, 07:30 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
To add to that Bruce, I'd like to know why the OP wouldn't update to the fix of the problem when he's having the problem now but would rather stick with the problem Somebody tap me on my shoulder & tell me to be quiet
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 09-05-2009, 08:12 PM
JMS40 JMS40 is offline
Stop confounding the OP with that dad burn Hillbilly logic.
Old 09-05-2009, 08:15 PM
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 09-06-2009, 02:35 AM
TOM@METRO's Avatar
Just sayin'
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 09-06-2009, 10:56 AM
I actually never made an image of my disk before. I only back up data on my HDs, not programs.
Music won't play. Play button flashes and Stop button lights up Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 04-16-2020 03:03 PM
I push PLAY and Stop Button lights up Blue ??? Seafoam_Green Pro Tools 10 3 07-06-2013 09:18 AM
Press PLAY and STOP button lights! ronlosangeles Pro Tools M-Powered (Win) 0 11-29-2011 10:19 AM
Delay When Record/Play Button Pressed kaoticjackal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-25-2009 01:42 PM
ProTools "stop" button lights up when I hit "play" andy knowles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-20-2005 12:07 AM
