Old 02-24-2018, 05:22 PM
efisch efisch is offline
Default Spinnng beach ball with "Auto Backup" on
Having a problem that's driving me nutty (or else I wouldn't be posting, duh). With Auto Backup on, I'm getting a quick (2 sec) spinning beach ball every minute or so. Seems to coincide with my backup setting of 1 min. Turned off Auto Backup and the problem went away. Track count is high, but I've worked with higher without a problem. HW buffer set to 1024, cache size 7 gb (although I have the problem no matter what I set that to). Plenty of room left on my SSD system drive, plenty of room on the work drive - video file on a separate drive. Thoughts?
Pro Tools HD 2018.1
Mac Pro 2 x 3.33 GHz 6-Core
40 gb RAM
Old 02-25-2018, 04:48 AM
Default Re: Spinnng beach ball with "Auto Backup" on
Two things:
Change autosave time to something like 5 minutes
Use cmd-S frequently for manual saves; the fingers of my left hand are semi-permanently bent in that position
Old 02-27-2018, 02:37 PM
Thanks Jack - Unfortunately didn't help. Just got a spinning beach ball every 5 min lol. Hope to talk to Avid today.
Old 02-27-2018, 03:16 PM
crizdee's Avatar
crizdee crizdee is offline
Any plugins in use that have sampled sounds to load and save? this can cause slow save/back up issues.
Any external hard drives connected?
Does it still do it if you test without the video?
Dont think auto back-up saves when the transport is running. Doesn't on version up to 10 but not sure from PT11 onwards. So is it exactly every 5 minutes?
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-28-2018, 01:54 PM
Yeah, the spinning beach ball happens when the transport is parked and I'm trying to edit. I don't think it happens when in play.
If I set the auto backup to one minute, it happens every minute. 4 minutes, happens every 4 min, etc.
Spent an hour and a half on the phone with Avid yesterday. Tried a whole bunch of "throwing stuff at the wall to see if anything sticks" fixes. Nothing helped. Finally he suggested that I un-mount my automatic backup drives (all internal/MacPro) and quit my backup programs. Work for a day and see if that helps. So far today it hasn't helped.
Next step is replace my work drive - maybe it's starting to fail. Stand by.
Where is the "Auto Renewal" Option in "My Products and Subscriptions"? jhowas Pro Tools 12 8 11-01-2015 02:34 AM
Spinning Beach Ball after using Auto Tune in Audio Suite Rule62 Pro Tools TDM Systems (Mac) 1 01-01-2013 05:00 PM
Pro Tools 9 — "Crystall Ball" plead... nod25 General Discussion 15 09-26-2010 12:09 AM
"access violation " protools can not make auto backup " nachonieto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-16-2008 03:54 PM
Is there a way to have "AUTO TALKBACK" engaged WITHOUT "Dim" happening? The Zone ICON & C|24 4 10-21-2008 06:03 PM
