Old 10-18-2021, 10:05 AM
Default Play and stay in b/g possible?
is there a way to keep PT in the b/g when hitting play on any of the Eucon transport options?
This happens whenever you have a selection in PT for loop playback. It stays in the b/g when using back+play (which clears the selection) or when you don't have a selection.
Would be great to start/stop PT and loop while it's in the b/g and not have it pop to the front. (while browsing sounds in Soundminer at the same time for example.
Thanks!
F.
PTHDn 2021.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 10-18-2021, 10:56 AM
lucas f. lucas f. is online now
Default Re: Play and stay in b/g possible?
There's is an option in eucon to lock the surface to an application..
Envoyé de mon SM-G960F en utilisant Tapatalk
Old 10-18-2021, 10:58 AM
Yeah, I meant the PT edit window popping to the foreground. It does that only when a selection is active in PT and you hit play on the EC transport.
Old 10-19-2021, 08:43 AM
I am also on PTHDn 2021.7 (OSX10.14.6) on a MacBook Pro with a Dock + S1 on the latest EuCon, and I can press play on the Dock with an active selection and Pro Tools in the background or even hidden, and it doesn't jump to the front. Could this have something to do with Rewire?
EDIT: Scratch the rewire idea, I just tried it with Soundminer and rewire active and the behavior didn't change.
Scott Gatteño
Old 10-19-2021, 10:11 AM
Thanks for testing this!
Yeah, I don't use rewire with SM. Strange that it doesn't do that on your system. I can reproduce this on 2 rigs over here. One with 21.7 and current EC and S1 and the other with 21.7, current EC and Artist Mix.
Can you try and turn loop mode on? I doubt that changes things but that's the mode I'm using. I don't have a Dock though so it could that.
Thanks again!
Frank
Old 10-19-2021, 11:35 AM
Thanks again!
Frank
Do you mean loop playback? I just tried with that on and nothing changed. I also tried using the transport on the iPad, rather than the buttons on the Dock. No change. What are you using for transport buttons?
Scott Gatteño
Old 10-19-2021, 12:29 PM
Yes loop playback. I have so far tried the transport buttons on the control app and I have play/stop and back+play set as softkeys on the S1. All have the same behaviour.
Old 10-19-2021, 02:07 PM
That's strange. I's all working fine here.
Scott Gatteño
Old 10-20-2021, 06:05 AM
JR Fountain JR Fountain is offline
FWIW mine works fine with PT in the background here too.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
Old 10-20-2021, 07:00 AM
Thank you both. It's weird, today it hasn't been happening all day. Maybe it was an esoteric glitch. Seems fine now. No popping to the front. I haven't changes anything On the other rig however is IS happening. Really weird.
Frank.
Should I Stay Or Should I Go (from 12.7.1 to 12.8)? rinky Pro Tools 12 36 07-25-2017 10:37 AM
From LE to HD should I stay 48k or go 96k? 192? churious Pro Tools TDM Systems (Mac) 2 07-25-2004 12:19 AM
OS 10.2.8 Stay away from it! gives Pro Tools TDM Systems (Mac) 12 10-02-2003 05:08 PM
Ok, should I go MAC or stay PC? Jayson Torres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 10-08-2002 11:35 AM
stay off my mac michael verdes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-14-2002 08:27 AM
