Old 08-13-2008, 11:16 AM
End of Stream End of Stream is offline
Default Pro Tools Critically Low on Memory & End of Stream Session Corruption
Any advice appreciated. I think this might be header corruption, maybe Rail Jon Rogut could offer some insight if around?
I was using Pro Tools 7.4cs5 with a 48K session on ext 1394 Glyph drive Mac OS Extended Journaled, 48 tracks very little automation, but lots of edits, just playing back audio when I got "Pro Tools is critically low on memory and must quit, press OK"
Pressed OK now the session won't open. I get "Could not complete the open recent session command because end of stream encountered". Tried 2 machines, 2 drives, import session data and always get end of stream error.
Strangely, there are no backups in the backups folder. Yet this is a global setting that has worked on all sessions so far.
Help! Any ideas on what could have caused the problem in the first place and is there a utility to repair the header of this session??
Session was an OMF from another studio that had QT video in it.
PT HD3, 4x 192 I/Os, D-Control , Mojo SDI, Ceder DNS 2000
Intel Xeon 6130 2ghz 3gb
HD3 pci-X in expansion HD
Old 08-13-2008, 05:07 PM
Default
ANyone?
Old 08-14-2008, 08:46 AM
Brandonx1 Brandonx1 is offline
Default
Hi End of stream,
I've had this problem. It happens to me when I have mix sessions that are and hour of tv program (44 min). 1/2 hour or 22 min work very well. If you open the task manager and watch the PF usage, you will see it increase over time. When it reaches 1.6 gigs or so, bam, you're screwed and hit with this message. I've stumbled onto a easy work around. I found all you have to do to reset the PF to a lower ,normal, level is to drag and drop an audio file from the desktop into PT. You can go on working for another three hours or so and then you will have to do this again to reset the PF usage. I guess this is a memory leak. Hope this helps.
Best,
Brandon
Old 08-14-2008, 08:48 AM
DigiTechSupt's Avatar
Default
This may occur in sessions created without Mac/PC compatibility engaged that have been copied from a Mac OS X machine to a drive formatted FAT 32 (MS-DOS), and then back to the macintosh hard drive.
Is this possibly the case here?
Avid Audio Tech Support
Support FAQ
Old 08-14-2008, 10:42 AM
x9blade x9blade is offline
Default
don't mean to hijak your thread end of stream. digi i think you may be on to something with the sessions coming from mac to pc. some sessions i work with are always going back and forth and there always seems to be some type of problem whenever i work with these sessions.not all but when the problems do happen they are a nightmare
i will check to see if the mac to pc box is being checked. some of the sessions were started pre protools 7. i will look into this to see if that may be my issue
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 08-14-2008, 10:44 AM
Default
It's a possibility, the session came as an OMF from an Avid system. It was being a bothersome session the whole time and seemed to be difficult to work with before this total loss of work happened.
Old 08-14-2008, 11:19 AM
Default
A little more info on this:
Copying a session that does not have Mac/PC compatibility enabled onto a non-macintosh formatted hard drive drive strips the resource fork from the session file. The file will be missing vital data that can only be recovered by going back to the original session file before it was copied to the drive.
Sessions that have been corrupted in this way are not recoverable, however, AIFF and WAV audio files may still be intact and contain time stamp data which may aid in reconstructing the session.
More information may be found here: http://www.macdisk.com/macforken.php3
Regarding the OMF - was this ever sent over a network, or been on an MS-DOS drive? If you're sending over a network, it's always a good idea to zip the files, that way the resource forks are 'hidden' and can't be stripped.
Another thing with OMF's from Avid - did they make sure to remove all offline regions from the timeline before creating the OMF?
Support FAQ
Old 08-14-2008, 11:23 AM
Default
One last note - the Mac/PC compatibility option was only available prior to version 7 - higher versions have it integrated automatically.
Support FAQ
Old 08-23-2008, 09:15 AM
Jeremy Lock Jeremy Lock is offline
Default
I too have had this problem, and believe that in my case it was down to the AAF that I received from an AVID. I've recently been bogged down with similar issues with OMF parsing errors when media from the AVID does not hold enough location data. To avoid problems I remove any regions from the playlist and region list which have not llinked to their media as soon as i import the AAF. This seems to head off the problem.
Old 08-23-2008, 10:18 AM
Default
Absolutely - remind anyone creating OMF/AAF to remove any offline regions before creating the OMF/AAF to avoid possible problems like this.
Support FAQ
Pro Tools is Critically Low on Memory MJarzabek macOS 38 11-10-2015 01:51 PM
Pro Tools Is Critically Low On Memory TinyE1017 Pro Tools TDM Systems (Mac) 35 02-08-2011 09:25 AM
Pro Tools is Critically Low On Memory TinyE1017 Pro Tools TDM Systems (Mac) 0 07-09-2010 12:56 PM
Pro Tools Critically Low on Memory & End of Stream Session Corruption marcblack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-29-2009 08:09 PM
Pro tools LE 8 critically low on memory maxxer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-10-2009 06:22 PM
