Old 12-18-2010, 02:28 PM
js1268 js1268 is offline
Default can't open older PT sessions...help!
okay, here's the deal
i wrote about a half dozen songs in what i think was PT 7 back in 2006 and 2007 on an Apple G3 running OS 9.2
I kept the files stored on a high performance SCSI drive
I dug out the old Mac, and fired her up....
Everything was still in tact.... and so I moved all the PT sessions onto a 4 gig USB drive so I could then store them on the external Firewire drive I use to record on my Macbook Pro via Mbox2 mini
BUT, when I go to open the sessions they are not recognized as PT sessions and I can't open them.. Furthermore, the audio files (although clearly large) don't have the .SD2 suffix on them
Now, I know PT 8 is backwards compatible and should recognize, open, and then allow me to subsequently save the session and ancillary audio (.SD2) files in accordance with PT 8 ...but that's not happening
What did am I doing wrong, here?
Anyone?
In desperate need of help.... Thanks
Paul
Old 12-18-2010, 02:53 PM
caruso7r caruso7r is offline
Default Re: can't open older PT sessions...help!
Anyone?
Paul
A couple of things happened here. First the real problem is that you moved the .sd2 files onto a usb fat32 formatted drive which can't properly handle .sd2 files and you lost the resource forks for those files. If you have the original sessions still on the old G3 then open the sessions on the G3, do a "save copy in" and convert the audio files to .wav, then copy all those sessions over to your newer system. The session document in PT7 should be handled with no problems from PT8 but the transfer of audio files .sd2 onto the usb drive formatted fat32 killed the audio files.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 12-18-2010, 05:58 PM
Indeed, John... Seems to be the case with transferring files across a FAT32 drive
The problem with opening the sessions on the G3 is that they were written with a Digi001, so I'd need the interface in order to open the sessions.... and of course, I got rid of that a long time ago
What about if I transfer the sessions and audio files across Firewire to a 7500rpm drive that was once in my old Apple 'Lombard' laptop? ...will I still lose the resource forks?
Thanks for your help!
Paul
Old 12-19-2010, 12:12 AM
Any friends with a mbox nearby? You could install an older version of PT for the mbox and then open the sessions. As far as the firewire transfer, is the drive formatted
mac hfs? If it is then you may be fine. Simply copy to that drive and then open the drive and sessions with your new mac. You do have other options, pulling the old drive
out of you old mac and getting a usb enclosure for the old drive and hook that up to the new mac to get your files back. Drives are cheap today so to me it's worth
buying a new usb/firewire drive, format mac hfs with the new mac, then hook it up to the old mac. If the old mac doesn't see it, you can reformat on the g3 mac hfs
standard hook it up to the new mac to make sure it sees it. After you have confirmed at least one of these ways work, then copy your session folders over to the new
drive.
John
Pro Tools 12.5
Old 12-19-2010, 09:35 AM
no, no friends with an Mbox...
Indeed, I believe the 7500rpm external drive is mac hfs....so i might be okay
those other options are also a way, too.... thing is, the internal drive i saved the sessions and audio on is an Ultra SCSI drive... no enclosures for that beast
BUT, I do have a spare ATA 133 drive that came out of a G4...so i could install that in the G3, and drop the sessions and audio files onto that....then just pick up a cheap USB or firewire enclosure and attach it to the new Macbook Pro
gotta be ways around this so I can get those files to work on
will keep you posted!
paul
Old 12-19-2010, 09:11 PM
Good luck and DO keep us posted. It's always good to know that these things will work out and at the worst we can all try another solution. Again good luck.
John
Pro Tools 12.5
Old 12-20-2010, 09:47 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
paul
This may help:
http://www.railjonrogut.com/sdTwoWav.htm
Avid Audio Tech Support
Support FAQ
Old 12-20-2010, 10:18 AM
Top Jimmy's Avatar
Why not reformat the 4 GB USB drive as HFS+? Mac OS does have a native disk utility.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 12-24-2010, 05:33 PM
alright, i did it!
no problems at all......
i transfered the files off the internal SCSI drive to an internal ATA 133..... then, i bought an IDE to USB 2.0 cable from CompUSA....and voila!
i then transferred the files to the firewire drive that i record to and opened them up... PT 8 told me that it would transfer the SDII files to .wav files upon opening and to save the session under a different name.... NICE!!!
incidentally, these were PT 5.1 sessions..... didn't realize just how old they were.... but it all worked out seamlessly
PT 9.0.5 - I cant open ANY older sessions... --- SOLVED !!! 25ghosts Pro Tools TDM Systems (Mac) 6 08-28-2011 04:46 PM
Cannot open older sessions! OxfordFishSalon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-09-2008 02:11 PM
LE 7.3.1 can't open Any Older Version Sessions Mono~Log 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-11-2007 11:37 PM
Can I open older 5.x TDM-Sessions with LE or MP? T-LAY Pro Tools TDM Systems (Mac) 1 06-17-2005 11:45 PM
Can't get PT 6.4 to open any older sessions Ave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2004 03:41 PM
