Old 08-24-2007, 11:19 PM
Mono~Log Mono~Log is offline
Default LE 7.3.1 can\'t open Any Older Version Sessions
Hi everyone,
i've upgraded recently to PT LE 7 (7.3.1-current version),a New PC and bought
a Mini M-Box. I thought there should be no problems opening my old sessions
with it but an unexpected message pops up while i'm trying to do so and i can't
realize where to start with so LE ver.7 accepts my old sessions done with 6.7
and other versions.
The message is: "Could not open because the session was created with an
invalid configuration of Pro Tools".
i'm using an "HP" P.C with windows Xp pro Sp2; Intel(R)Core(TM)
Dou 6300 @ 1.86GHz CPU, and 2GB RAM Memmory.mainly, i do
post-production editing works with PT.
I know someone who had the same problem with M-powered version
(a post i found here), mannaged to solve it by changing
the Language and regional settings of his new System ,matching
it with what he had in the old pc where he created the old sessions.
well, it didn't work for me, no matter what i tried, and i tried
any possible combination
Help!
thanks.
Nissim (Mono)
Old 08-27-2007, 02:18 AM
Default Re: LE 7.3.1 can\'t open Any Older Version Sessions
Anyone? Please help
Nissim
Old 08-27-2007, 03:20 AM
Kirby B. Kirby B. is offline
You mention language settings, implying that your PC might not have an English language OS. I would check with Digi. I checked around and found this thread http://duc.digidesign.com/showflat.p...9&Main=1094651 which also points to language settings. best of luck.
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 08-30-2007, 03:13 PM
cheers Kirby,
My PC has an English OS installed, only with an additional foreign language
so i can read and write in my native language.it's something i have always
had whithin all my OS.
i'm familiar with that post you mentioned. seems like they had luck...
i tried everything they suggested. basically what's said there is to change the
current OS language settings so it matches what you had when creating the 6.7 sessions.
well, did that.
i even tried on an other PC, creating a new LE 6.7 session with the same OS language
settings i have currently installed, but my LE 7.3.1 wont accept it.
go figure..
anyways, i keep on trying. i might contact my dealer if i'm stuck with it as is. maybe he has
the answer. it ussually is so simply "stupid" one, one can't understand how he couldn't see it earlier...
But,
thanks!
Nissim
Old 08-30-2007, 03:33 PM
Bob L's Avatar
Bob L Bob L is offline
Were the 6.7 sessions recorded on a Mac? If so, were they saved using "Enforce MAC/PC Compatibility" checked?
Bob
Avid shall not see another tax dime from me.
I have not, nor will I ever subscribe a DAW.
DigiTechSupt's Avatar
Is this Pro Tools LE 6.7 you're working with? Which LE hardware is on the 6.7 system?
This sounds like some kind of session corruption - can you open the sessions in any *other* version of Pro Tools, say 6.9? If you can and do a 'Save Copy In', can you then open the newly saved version in Pro Tools 7.x?
Avid Audio Tech Support
Support FAQ
Old 08-31-2007, 09:20 AM
BOB L.
some of the sessions i tried to open were done on MAC, DIGI888 Hardware and PT TDM. when I created these sessions i actually did check the "enforce PC\Mac" box. i was able to open these sessions
on LE 6.3,6.7 and 6.9 and also on TDM.
Old 08-31-2007, 09:36 AM
It wasn't only LE 6.7. the last one was.
while working, I switched between TDM 6.4 with a DIGI-888 hardware
to M-box with LE 6.7 and 6.9 sometimes and vice versa, between a Mac and a PC, and there were no
problems. all of those systems are part of a college post production studios, I sometimes
use.
yes, i can open the sessions in all of these other versions i mentioned.
i haven't tried yet what you suggested with the 6.9 but i will try and post my results here.
Old 09-04-2007, 05:44 AM
well, I tried:
As LE 7-7.3.1 Won't accept 6.7 sessions, it won't
accept 6.9 as well,even when i use a "save a session copy in..." command.
with exactly the same OS configuration. I have no clue of what to do.
i'm trying to contact my dealer now, maybe he has some answers.
if anything pops up in your mind, post your thoughts here.
cheers
Nissim
Old 09-07-2007, 05:14 AM
ability ability is offline
I just wanted to upgrade my 001 to 003 including 7.3.
So does everyone has that backwards compatibility problem with older sessions ?
Or are you just the unlucky one....
Because i am in the middle of recording an album, if its not supported by 7.3 i wont be able to open all the "great" songs i have mixed so far in 6.4...
If you find out please let me know...
goodluck!
PT 9.0.5 - I cant open ANY older sessions... --- SOLVED !!! 25ghosts Pro Tools TDM Systems (Mac) 6 08-28-2011 04:46 PM
can't open older PT sessions...help! js1268 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-24-2010 05:33 PM
Cannot open older sessions! OxfordFishSalon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-09-2008 02:11 PM
Can I open older 5.x TDM-Sessions with LE or MP? T-LAY Pro Tools TDM Systems (Mac) 1 06-17-2005 11:45 PM
Can't get PT 6.4 to open any older sessions Ave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2004 03:41 PM
