Old 10-31-2003, 03:06 PM
badperson badperson is offline
Default skipping bounce to disc and mxing down to dat
Does anyone do this? Instead of bouncing to disc, having an out on the master fader, going thru a tube comp\limiter and onto a dat?
I read about this someplace, and was wondering if skipping the d/a conversion could be a plus. Well, that probably isn't a good way to put it, you have to do d/a conversion somewhere along the line, but would staying at 24 bit help?
Also, if you did what I outlined above, putting an audio out on the master fader, then going into a comp/limiter, and onto a dat, where exactly would the d/a take place, and how would it be different from bouncing to disc?
Also, how would it differ from going out of PT, into the comp/limiter, and back into PT? Would there be a noticeable difference?
thanks.
bp
bp
Old 10-31-2003, 04:29 PM
Lowfreq Lowfreq is offline
Default Re: skipping bounce to disc and mxing down to dat
BP - about 30 percent of the time I mix down to my DAT machine. I have a typical tiny home studio and record demos & such and some clients or ME's ask for DAT masters. But usually with no limiting/effects on the master fader (minus dither/resampling). A few times I have used outboard limiters (post dither) in between. When mixing down to DAT you can't be too hot in level as clipping a DAT machine sounds like the sky is falling.
Old 10-31-2003, 05:04 PM
Viktor Viktor is offline
I used to mixdown exatly the way you pointed above.Then I switched to "bouncing to disk" but still not sure this is right.Anyone has a "second opinion"?
Old 10-31-2003, 11:56 PM
Jace Everett Jace Everett is offline
I have bounced to disk.
I have sent my Master fader spdif out to a Masterlink CD burner (Alesis).
I cannott tell much difference in audio quality. One thing I have noticed is that if your only "mastering" tools are to throw a C4 and a Limiter on the Master fader, though you'll get a loud and fairly dynamic mix, you tend to get a mix that feels "hollow". I'm not educated enough to explain it, but you seem to miss out on the more analog sounds (to me lo and hi mids)of an old school mix.
I have a buddy who bounces to disk then actually records the CD to analog tape and runs it back in to ProTools. He swears by it.
Of course he smokes a lot too...
Mac Pro 2.4 Quad, 8 Gig RAM Snow Leopard 10.6
HD Native PT 10
Omni
Waves Platinum
NI Komplete 8
API 512c, LA 610
Some Mics, Some guitars
Some Songs
Won't bounce to disc standish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-20-2007 05:42 PM
Audio skipping during bounce??? captninja Pro Tools TDM Systems (Mac) 3 10-06-2006 03:55 PM
Bounce to disc? Appreciate any and all help. Elvisaintme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-05-2003 06:58 AM
bounce to disc MP3 fredsparky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-25-2003 10:32 PM
Bounce To Disc - Help emd2449 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2002 11:42 AM
