System 5 Side-Chain from surface
I am looking into side-chaining piano to strings compression or kick drum to bass guitar compression.
On the S5 surface I have the compressor on (Bass) channel 1 and kick on channel 2. On the bass channel I enabled SC then select channel, key or link. When set to key the bass track is muted as it should but now I select channel and want to grab the kick drum channel but cannot figure out how. I know side-chain within eMix and Nuendo works but I would like to quickly setup side-chain from the S5 surface. Can someone in S5 land chime in?
Windows Pro 10 X64 - Pro Tools 12.8HDX Windows Pro 10 X64 - Nuendo 10 Windows Pro 10 X64 - Cubase Pro 10 Euphonix System 5, 408's, 401, 402, 403 eMix 6.1.1.20.1, HybridAPP 20.1, EuconWS 3.6.1 |
Re: System 5 Side-Chain from surface
Have you patched the side chain ? (I presume you are talking S5 DSP not EUCON ?)
Is it possible to side-chain an EQ? | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2009 06:00 PM |
How do I set up a Side Chain | junglelabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-30-2007 10:49 PM |
Side Chain | ByPass | Tips & Tricks | 1 | 05-08-2007 12:33 PM |
A better way to side chain? | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-24-2007 04:40 PM |
Side Chain Processing | tbp04 | Tips & Tricks | 6 | 01-03-2007 03:04 AM |
