Old 02-16-2010, 04:29 PM
mofotan mofotan is offline
Question Ways of the Mastering?
Hello folks! Here is my situation. I have mixed a session and I am ready to master. Do I make sure before I bounce to multiple mono L and R that my levels on the master( Fader set at 0) don't go past 0?. If this is true ,do I group all the faders and go up or down to hit 0? This is what I have been doing. My other question is that I have a couple audio tracks with automation(levels for dynamics),is there a way that it will stay relative to adjustments or will I have to "write" new auto data? Need help from you pro's!!! Thank you in advance!!
PT 8.0.3 cs1
003
Imac 2 ghz
3g of mem
Old 02-16-2010, 04:36 PM
The Dougfather The Dougfather is offline
Default Re: Ways of the Mastering?
Typically you would bounce the file down and then work on single stereo interleaved file within Pro Tools or your DAW of choice.
Mastering is a bit of a black art and something i am working on as we speak and i still feel as though i've only just scratched the surface several years down the line.
If you have the time i'd recommend taking a look at Izotope Ozone 4, it's a fantastic mastering plugin that get's great results. At a the same time you really need to read the documentation so that you use it correctly. Izotope have a mastering with Ozone guide and it's a great read, even if you don't intend on mastering with they're software the info is relevant. It's also a very easy read without too much teccy jargon. Whatsmore if your not comfortable with doing it all yourself they're a shed load of presets to get you off the starting blocks.
http://www.izotope.com/products/audio/ozone/guides.html
Good luck.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 02-16-2010, 04:41 PM
jdutaillis jdutaillis is offline
When bouncing out to master you want to keep the master fader from clipping (so no red lights! not even one!). If you have all your track and bus levels set how you want them and dont want to muck around with changing your automation levels then simply pull the master fader down so that it doesn't clip when playing back.
Another consideration is the amount of headroom you want to leave for the mastering process. I usually leave around 6dB roughly, and try to have my mix peaking at -3dB at the most. Im not sure what levels other people go for here but I would be interested to find out!
REAPER | Prism Sound Orpheus | ProTools LE 8.0.3 | M Box 2 | Edirol PCR-M50 | Genelec 8020a Monitors + 7050B Subwoofer
i7 950, Gigabyte UD4P MoBo, 6GB Corsair RAM, Gigabyte NVidia Silent Cell 9800GT 1GB, Seagate 1TB HDD (2 x 500gb partitions), WD 500gb Caviar Black, Samsung SW2333+, Windows 7 Professional 64bit
Old 02-16-2010, 04:43 PM
Thanks for your prompt response. But....am I making any sense about the levels? I know you are very wise and have years in this field. Any suggestions about the automation I asked about. Thank you!!
Old 02-16-2010, 04:47 PM
Kind of confusing dude.....
You bounce your mix down as is. What you hear is what you get, just make sure your not clipping on the master fader when the file bounces down.
Once you have your bounce, take it back in to Pro Tools and master to taste.
If you try and group all the faders together and move them all up together to increase your levels the the mix is going to fall apart. If you want more volume before you bounce add a plugin on the master fader, something like massey tapehead, maxim or even a compressor will do the trick. Just bare in mind one of the mastering objectives will be to bring up the levels so you really don't need to worry about adding volume right now.
iCON Photography
Old 02-16-2010, 04:50 PM
Hello jdutaillis, I needed the confirmation. I thought about the master fader but wanted verification. So.....there is nothing I can do about automation staying relative to my adjustments? Oh yeah, about the master fader is that shunned upon and used for last choice or do you guys do it all the time? Thank you!
Old 02-16-2010, 04:51 PM
If you group all the tracks then adjust the levels with the faders, beacuse you have put in automation data, the faders will return to the levels that you have automated... What you have to do in this situation is in the edit window, change track view to volume, highlight the whole song on each track. Now using the multi tool, place the mouse just above one of the volume lines and raise the level how you want it. This will place points at the begining and end of each track and raise the levels of everything in between, keeping the ratios of the automation that you have done.
Old 02-16-2010, 04:52 PM
It comes with practice, if you start with your faders too high then the master will clip. If you ease off it won't clip and you will leave yourself some headroom.
iCON Photography
Old 02-16-2010, 04:55 PM
I gotcha now.
If you insert a trim plugin on your automated tracks you can adjust the overall gain of the track up or down.
iCON Photography
Old 02-16-2010, 04:58 PM
I don't usually have to use the master fader at all, but that's just the way I mix, making sure nothing will clip along the whole way and keeping alot of headroom available.
As far as I know pulling down the master fader to avoid clipping doesn't have any negative effects...
So many ways to do the same thing ! Terry Wetzel Windows 2 02-25-2013 06:32 AM
Ways of working in PT Michael Erlandsson Tips & Tricks 4 03-26-2006 10:06 AM
Let me count the ways... ostrich99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-07-2003 02:41 PM
Two ways of BTD... OgnKog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-21-2002 10:13 AM
101 ways to ask the same question PT & OSX DesertDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-07-2002 08:08 PM
