Old 07-24-2014, 08:00 PM
smokeandshadow smokeandshadow is offline
Default Slow clip rendering?
This is difficult to duplicate, as if sessions randomly corrupt or something, but recording passes suddenly take several seconds to render or "hiccup" if you like. 7200rpm internal 6GBps Sata III drive for my recording disk, so no issues there, it seems to be PT exclusive as well. Anyone else have a similar issue? 11.2 here on windows 7 and 11 rack, buffer at a safe 512 and 48/32 float.
Old 11-08-2015, 05:22 PM
entropylabs entropylabs is offline
Default Re: Slow clip rendering?
Same type of problem. When recording audio there is a 2-3 second pause (no pre roll) and when I stop it takes 7 seconds to render the recorded audio so I can listen to it. Been thru all the usual optimization and HD checks. Just started with PT 11. May need fresh install or move to 12.
Any solutions from your side?
Audio is out of sync after rendering clip gain JWalkerPostAudio Post - Surround - Video 27 09-11-2012 07:55 AM
Slow Batch Fade Rendering SunsetLodge Pro Tools TDM Systems (Mac) 2 05-24-2012 10:10 AM
Region Clip Indicator after rendering Steve Marcotte Pro Tools 9 2 03-25-2012 09:31 PM
Q re: Rendering Clip Gain EricWillhelm Pro Tools 10 1 11-21-2011 10:49 AM
rendering Elastic audio stil slow Zownd Pro Tools 9 7 11-18-2010 01:03 PM
