Old 04-27-2004, 08:56 AM
EasyStreet EasyStreet is offline
Default How to do +12 fader on ProControl ?
I've been waiting about a week for somebody else to ask the dumb question - so here goes:
In the new PT version 6.4 we can do +12 on a channel fader (instead of +6).
Anybody know how this will work on a ProControl, whose top range of the fader is stenciled at +6?
Will it just say +6 and BE +12, will it be a setting, what?
EasyStreet
Old 04-27-2004, 10:05 AM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
Default Re: How to do +12 fader on ProControl ?
Yes.
When you make a new session you will be able to choose +6 or +12. The first time you open an older session Pro Tools will ask if you want to switch it to a +12 session. The automation data will not change (it will still be based on +6), but subsequent automation passes can take advantage of +12.
Be aware that changing the session to +12 may cause problems if you take it back to a +6 system. Any data above +6 will simply plateau at +6.
Old 04-27-2004, 10:11 AM
charles maynes charles maynes is offline
One of the people I work with has 6.4 LE, and here is what I found-
There is a choice when creating sessions to use the standard "+6" volume behavior, or the new "+12" behavior" It seems that the best way to deal with it outside of 6.4 is to simply put a trim plugin on your master buss and set it for +6 before you start mixing.
I think this would be fine for 24 bit sessions, but Dither would be needed.
Charles Maynes
Old 04-29-2004, 04:03 PM
No... -1dB on 6.4 would still be -1dB on 6.1.x and earlier.. but if you place a trim plug-in with +6dB your -1 on 6.4 will be +5dB.
If you plan to go back to an earlier version of Pro Tools I suggest keep using +6dB as your max fader value.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-29-2004, 05:03 PM
Rail-
Thanks for the info-
I have not used 6.4, but only got the info from the LE system we have here.
A question though-
If you start a session in the +12 mode, then move it on to a non 6.4 system, does the level drop 6db? I am curious, because it could cause all sorts of session compatibility problems.
I would think that the 6.4 mixer would handle this, but earlier mixers would be unaware of the session pref.
Best Regards-
Charles Maynes
Old 04-29-2004, 11:03 PM
Any volume level above 6dB will plateau at +6dB.. everything else will be the same.
Rail
Platinum Samples
Old 05-04-2004, 11:31 AM
CLee CLee is offline
So if your PC says +6 at the top of the fader but your gain in PT is +12 is zero going to be at zero or -6 (which isn't marked) ?
Craig Lee@Cerny American
Old 05-04-2004, 02:52 PM
Zero is always zero.. it's a simple matter that instead of 6dB above zero.. you have the option of +12dB like on a normal analog console.
Rail
Platinum Samples
Old 05-05-2004, 09:21 AM
I was just wondering how that lines up with the gain scale screening on the faders
Old 05-08-2004, 03:03 PM
Zero will be zero - and where it is screened +6dB would be +12dB. If this is an issue for you.. simply always keep your sessions at +6dB.
Rail
Platinum Samples
FS:24 Fader ProControl ZEUSS Buy & Sell 10 01-12-2015 09:35 PM
ProControl Fader Dead gearhead2010 ProControl, Control|24, Command|8 16 02-26-2010 09:52 PM
Would you buy a 48 fader ProControl rig now? guitar012001 ProControl, Control|24, Command|8 5 08-15-2009 05:46 PM
'Fader Pack' and ProControl Fader order issue Ciaran ProControl, Control|24, Command|8 2 03-21-2005 11:58 PM
ProControl Fader engineerjoel ProControl, Control|24, Command|8 1 01-30-2004 09:34 AM
