Old 01-11-2006, 06:18 PM
c-post c-post is offline
Default Beat Detective is driving me batty
I will readily acknowledge I am a novice at Beat Detective. But it shouldn't be this hard! Once I generate an analysis, which is quite faulty, I am unable to effectively add beats or bars where I want them, and the "promote beats" function doesn't seem to work at all.
I'm simply taking 8 opening bars of a 4/4 piano cue from a Broadway show, isolated it in a selection, specified 1-1 as the start beat and 8-4 as the end beat. There are 8 bars in the area I am attempting to detect. Beat detective finds beats, but fairly randomly. Most frustrating of all is that I can't add or promote beats. WHY CAN'T I ADD BEATS!? COMMAND CLICK does nothing. aaargh. If I command click on an existing beat or sub-beat, the line creeps up to yellow, but nothing seems to happen. No change, no improvement.
what works: I can delete beats. I can move beats, but it causes other things to shift around sometimes. I feel like I have no control over this. Help me take off my dunce cap.
thank you
-John
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 01-11-2006, 07:19 PM
thebigshow thebigshow is offline
Default Re: Beat Detective is driving me batty
Don't use beat detective...simple as that
(Sorry that doesn't help, but i h8 that prgm)
Old 01-11-2006, 08:58 PM
I am studying a lot of archived posts, but no epiphany yet. Not at all. Somebody recommended manually inserting beats. Fine, I go to the beginning of each beat transient, which is easy to identify, hit control I...a whole series of them. That's easy. My meter is 4/4. Now what?? I'm still stuck with the old "default" midi tempo that was already there. How do I recalculate or renumber the tempo map??
I am using this live track, and I want to add MIDI tracks to it, have a 4/4 click at the proper tempo, locked into the live track. Am I doing something wrong?
-John
Old 01-11-2006, 11:45 PM
Andre Knecht Andre Knecht is offline
Just a thought, which may or not have any bearing on what you’re currently wrestling…
You write "…I'm simply taking 8 opening bars of a 4/4 piano cue from a Broadway show, isolated it in a selection, specified 1-1 as the start beat and 8-4 as the end beat. There are 8 bars in the area I am attempting to detect."
Well, eight bars should be specified as 1:1 to 9:1. What you described is one beat short of eight bars.
IHTH.
Note to self: “One beat short of a bar.” Use that again and again, for a while.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 01-12-2006, 05:35 AM
Riccardo Corbari Riccardo Corbari is offline
to add: simply click on the lower side of the track with the smart tool, when the cursor becomes a hand like holder.
to cut: apple-click or opt-click, i don't remember.
do always capture selection and analyze beat
Studio Fuoriporta - Italy... verily everywhere...
Old 01-12-2006, 09:42 AM
"to add: simply click on the lower side of the track with the smart tool, when the cursor becomes a hand like holder."
Nope, it doesn't work. I see the hand, I click at what I recognize as a beat location, I see a vertical bar as long as I hold down the mouse, but it doesn't stick, the bar disappears when I release.
In the meantime, I may have been asking the wrong question. What I really needed to understand was the "Identify beat" command, not so much Beat Detective, and I think I've got it. I've had my nose in post for so long and now I'm coming up to catch some music/technical issues again...
-JOhn
Old 01-13-2006, 01:46 PM
bennychico11 bennychico11 is offline
you need to SELECT the 4 bars...not just put your cursor there...PT doesn't know how long your 4 bars is in sec:min which is how it figures out the tempo.
Old 01-13-2006, 04:08 PM
RIO RIO is offline
Just a thought. Make sure you have the correct 'contains' value selected. I think it defaults to quarter notes which can cause it to act in the way that you're describing. If you trying to detect beats that shorter than quarter notes, make sure you select the appropriate value.
Robert
Tempo mapping Beat Detective or identify beat? grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2012 09:13 PM
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! Robbry Pro Tools M-Powered (Win) 0 02-24-2010 02:14 PM
what do grid lines do after beat detective bar-beat markers cc1 Pro Tools TDM Systems (Mac) 1 05-22-2007 09:34 AM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 01:31 PM
-6101 Error...driving me batty. Scott Stillwell Pro Tools M-Powered (Mac) 6 01-03-2006 10:37 AM
