Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 05-05-2019, 11:08 PM
ptfwtf ptfwtf is offline
Default Delete unused tracks in PTF
Cloud space says it's filling up... but doesn't seem to delete tracks I'm not using.
And not able to delete takes.
Any ideas?
Old 05-06-2019, 07:53 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Delete unused tracks in PTF
Deleting Tracks
When you delete tracks, your audio or MIDI clip data remains in the project, but your arrangement of the clips on the deleted track will be lost.
The Delete Track command cannot be undone.
To delete a track:
1 Click the name of the track in its track channel strip to select it.
To select multiple tracks, Command-click (Mac) or Control-click (Windows) additional Track Names.
To select a range of tracks, Shift-click additional Track Names.
2 Do one of the following:
Choose Track > Delete.
In the Track List, or Mix or Edit window, Right-click the track name and select Delete.
3 Click OK to remove the selected tracks from the project.
You should also remove any unused clips to save space in your project.
Will K
System Details
Old 05-06-2019, 08:01 AM
Thanks for the reply.
How do you remove unused clips?
Also, when I delete a track, I still see it in the Clout to be downloaded in the Tracks. They never disappear - and keep taking up space.
Thanks
Old 05-08-2019, 07:54 PM
Originally Posted by junkgear View Post
Deleting Tracks
How do you delete clips? It seems like it's not possible, or am I missing something?
Old 05-09-2019, 06:52 AM
junkgear's Avatar
Deleting Underlying Clip Data
When removing a clip or selection, you can choose to remove or keep the underlying clip data.
To delete a clip or selection along with the underlying clip data:
Choose Edit > Cut.
To delete a clip or selection without removing the underlying clip data:
Choose Edit > Clear.
Will K
System Details
Old 05-09-2019, 09:31 AM
Choose Edit > Cut.
So what if I have a bunch of takes that recorded over the same track.. the clips and waves are still part of the project.
Or.. if a clip has been cleared.. how do you delete it.
And how do you get to a list of everything in the project that is taking up space in the cloud to remove files to free up space?
I don't think you can - I think the project just grows until it's too big.
But maybe I just don't know how to do it. In Pro Tools SE, you would just delete clips from the clip list. There is no clip list in Pro Tools First that I can see.
Old 05-09-2019, 04:26 PM
junkgear's Avatar
I don’t know why they removed the clip list from PTF, but see this article for a workaround.
Will K
System Details
Old 05-09-2019, 08:30 PM
The sentiment of the author of the work around is right... why remove the feature? I think it's because it's designed to fill up your cloud space with no way to remove files.. so it eventually forces you to upgrade your cloud.
And the work around lets you remove the files from your computer - which is no different than navigating to them in File Explorer. But either way, the cloud space doesn't shrink..
CLIPS > Select > Unused is unchanged after running Delete Unused SigFriedChicken macOS 1 07-02-2017 09:25 PM
delete unused tracks ihoward Pro Tools 11 2 04-13-2014 07:17 AM
Delete Unused Tracks works on my Mac. How on XP? sndchck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-16-2006 01:19 PM
digi 001 delete unused tracks soulshock7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-28-2005 06:30 AM
The best way to delete unused tracks in the edit window? Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-07-2000 12:46 AM
