Old 01-28-2017, 09:08 AM
TheGrobinson TheGrobinson is offline
Default Thunderbolt via HD Native box vs. Strictly Thunderbolt
Curious question comes to mind now that I'm starting to see interfaces with a combination of Thunderbolt and Digilink I/O
I can hook a Focusrite Red Pre8 to my Mac via Thunderbolt and work in PTHD or PT Vanilla just the same. The same hardware unit offers digilink connectivity. To use this I'm going to need to get my hands on a HD native box ($700 after market?) to ultimately go to Thunderbolt and connect my Darth Trashcan Mac Pro.
The point of my observation is the question, what can be gained by not going Thunderbolt the whole way and using Avid's Digilink and Native I/O box instead?
Old 01-28-2017, 09:56 AM
Drew Mazurek's Avatar
Default Re: Thunderbolt via HD Native box vs. Strictly Thunderbolt
Primarily the 32 channel I/O limit.
Also, if Focusrite mimicked the Avid boxes delay exactly, hardware inserts and anything "timing" related would be more accurate and automatic.
LLM mode might be better tighter??
http://www.avid.com/pro-tools/compare
www.drewmazurek.com
Old 01-29-2017, 11:40 AM
propower propower is offline
The Red 4Pre does not accurately mimic an HD I/O. The D/A and A/D are slightly longer than an HD i/O making all accurate pacing of audio on timeline and inserts off
Data I took when I had a Red 4PRE
Red 4pre
96kHz (HDX)
RTL = 0.576ms no sub master straight in and out
(AVID I/O is 0.48ms)
RTL = 0.62ms with one submaster
(AVID I/O is 0.52ms)
RTL = 0.912ms with loopback error fix
Loopback error is 35 samples late
About 0.4ms hit for getting loopback working right
Using I/O insert ADAT2 to ADAT1
RTL = 0.912 (one sub master)
Setting HW delay comp to 1.1ms gets loopback error to be zero - no effect on RTL
Logic w/ Thunderbolt - 44.1
RTL = 2.86ms 32 buffer - Logic displays correct value!
Logic 48
RTL = 2.6ms 32 buffer - Logic displays correct value!
Logic 88.2
RTL = 1.84ms 32 buffer - Logic displays correct value!
Logic 96
RTL = 1.7ms 32 buffer - Logic displays correct value!
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT2019.x Orion Studio 2017, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
HD native thunderbolt with thunderbolt card on desktop PC? martthie_08 Pro Tools HDX & HD Native Systems (Win) 9 10-12-2016 10:26 PM
WTB: HD Native Thunderbolt Becharax Buy & Sell 0 05-15-2014 04:13 AM
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
Until Someone Makes a Thunderbolt Hub, Thunderbolt is a (1/2 Useless) Dead End Street relaxo Pro Tools 10 7 11-12-2012 11:43 AM
Thunderbolt-Sonnet’s Echo™ Express PCIe 2.0 Expansion Chassis with Thunderbolt™ Ports Barry Johns Pro Tools TDM Systems (Mac) 29 08-11-2012 07:01 AM
