Old 08-30-2004, 11:19 AM
altemir altemir is offline
Default MIDI Search and Replace Function?
Does Pro Tools LE have a MIDI search and replace function that would, for example, allow me to search for all the C#2's in a given track and change their velocities to 87? If it exists, I'm just not seeing it.
Thanks in advance!
Old 08-30-2004, 01:08 PM
myfm myfm is offline
Default Re: MIDI Search and Replace Function?
AFAIK, PTLE's midi doesn't have a search and replace function per say, but it does have 'select notes' under the midi menu which I believe will do the same thing. Use the selector tool first to highlight the area with the notes you want to change, and then use select notes.
You can also use the grabber tool (the hand) and select the notes you want (it puts a block around them), switch to velocity view in the edit window and then change the velocity. With the grabber, all you have to do is select the notes, with 'select notes' you have to make a selection first before using select notes; then switch to velocity view to change the velocity in either case. With PTLE's midi, nothing is as simple as just do it.
Could Mac search/find really replace SFX software? CCash Post - Surround - Video 9 05-22-2005 07:48 PM
Search function Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-01-2005 05:35 AM
Can't Find "Replace Region" function ?????? KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-11-2004 11:03 PM
What's up with the DUC search function? Amerihudge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2003 02:01 AM
Replace Region function in v 5.0 KingTor Tips & Tricks 0 12-14-1999 05:26 PM
