Old 07-14-2017, 10:25 AM
composergarrett composergarrett is offline
Default Always Calculating Waverform Overviews
Since upgrading to PT 12 several months ago I haven't had any issues. In fact, it's been great!
However, since the latest update PT is forgetting the previously drawn waveform overviews completely killing my sessions. As some of my clips are over an hour long (one of the things I do is work on podcasts) it can take over an hour to re-draw.
Why is this happening? How can I prevent this from happening again?
It is random and inconsistent. I cannot recreate the problem intentionally. It will happen in the middle of editing. It will happen after recording.
I've read the posts from the past regarding previous versions with similar issues and as far as I can tell my system is set up correctly.
I use an external HDD formatted to OS X Extended (Journaled) for my PT sessions.
Thank you!
Old 07-14-2017, 10:29 AM
john1192 john1192 is offline
Default Re: Always Calculating Waverform Overviews
Thank you!
"as far as I can tell my system is set up correctly" you have not mention anything about your system except for the "external HDD formatted to OS X Extended (Journaled) for my PT sessions"
we could use more information .. we know it is MAC .. what else can you offer up system wise ??
help us help you ..
and welcome to the DUC ..
john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 07-14-2017, 10:41 AM
I'm sorry! I had put all the information in my profile when I created the account. I just assumed it would be in the signature.
Macbook Pro 15" (early 2011)
OS X 10.11.6
2.2 GHz Intel Core i7
16 GB 1333 MHz DDR3
AMD Radeon HD 6750M 1024 MB
PT 12.8.0 (on subscription)
Old 07-14-2017, 10:46 AM
Mixchump Mixchump is offline
I've had this issue as well, and it coincides with any time I mount my external recorder (MR2000S) as a USB drive. The second it mounts, half of my waveforms disappear and PT immediately starts regenerating them. It's a real drag because I print a mix to my machine, mount it as USB to transfer the DFF file over to my Master Mix folder, and I end up having to quit the mixed session file before it recalculates waveform overviews... I can't wait around for it to do that, I've gotta get on to the next song.
I'm also on PTHD 12.8.0, and MacOS 10.12.5 on a Late-2012 MacPro with upgraded dual 6-core CPU's (12 cores with HT), and 48GB of RAM. I've allocated 12GB as Ram Cache. Playback engine is HDX with 1024 Samples of Hardware Buffer.
Old 07-14-2017, 11:10 AM
OS X 10.11.6
16 GB 1333 MHz DDR3
if you see USER CP at the top left .. you can edit your signature .. it does not happen automatically ..
thx for the info .. now maybe someone can chime in with a solution .. i personally have never seen this .. cheers john
Old 07-14-2017, 11:44 AM
clausiii's Avatar
clausiii clausiii is offline
Do you start from a session template? If yes, then PT puts (sometimes) the waveform cache into the template folder. To avoid this, create the session from template, save it, close it, then open it again and then the cache is where it should be.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 07-14-2017, 12:32 PM
This is happening inside older sessions. My work flow includes swapping out the interview audio of the podcasts while the other tracks have all the components in place (music, voice over, etc.). I've tried saving as a new session and it doesn't help.
OS X 10.11.6
16 GB 1333 MHz DDR3
Old 07-14-2017, 12:38 PM
Norad155 Norad155 is offline
I've seen this too... coincides with mounting a drive... pinwheels the session then starts recalculating... new in 12.8
can't remember if it happens with network drives as well or just externals...
osx 10.11.6
pt 12.8
mac mini quadi7
IMDB
Old 07-16-2017, 06:19 AM
That makes sense, but I cannot figure why it's happening while I'm in my session. The HDD is not un-mounting and re-mounting while I have the session open (to the best of my knowledge). The waveform calculation just *happens* while I'm in the middle of editing.
I'll try running the session from a Firewire drive instead of USB and see if that helps eliminate the problem.
Thank you!
OS X 10.11.6
16 GB 1333 MHz DDR3
Old 07-16-2017, 09:14 AM
frenchman frenchman is offline
I get this kind of behavior sometimes and it confuses my Sync backup program, because when redrawing it changes the modification date of most of the files. This lengthens the backup process as it rewrites files that were untouched
Mark Haliday
Engineer, Producer
Calculating Waveform Overviews.... forever?! davedotpez Post - Surround - Video 2 07-09-2015 07:01 PM
Calculating Overviews p**ing me off! KMcK macOS 10 09-02-2013 06:39 PM
PT10 : Calculating Overviews midnightrambler Pro Tools HDX & HD Native Systems (Mac) 3 08-10-2012 07:56 AM
pt8 calculating overviews - backup nightmare sammyfarr Pro Tools TDM Systems (Mac) 11 02-18-2009 06:25 PM
Calculating overviews when loading stevegalante Pro Tools TDM Systems (Mac) 1 04-22-2000 10:32 AM
