Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 08-16-2015, 11:40 AM
trimph1 trimph1 is offline
Default Windows 10 and Pro Tools/First?
I upgraded from Windows 8.1 and now this...is this thing still a go?
Old 08-16-2015, 12:12 PM
DigiTechSupt's Avatar
Default Re: Windows 10 and Pro Tools/First?
Hi Trimph1,
Unfortunately, there is no version Pro tools yet compatible with Windows 10.
http://avid.force.com/pkb/articles/e...-Avid-Products
Regards,
YD
Avid Audio Tech Support
Support FAQ
Old 08-16-2015, 06:30 PM
Le Sigh. I should have checked it out BEFORE I updated....
I'll see what this does then....
Old 09-09-2015, 05:36 PM
mcburn13 mcburn13 is offline
I can actually get PT First working in Windows 10, by setting the protoolsfirst.exe to run in Windows 8 compatibility mode. BUT, I can't seem to get it to recognize any but the OOB plug ins. I installed the x64 Thump Plug in from Avid but it doesn't show up. Anyone?
Old 09-09-2015, 06:03 PM
mesaone mesaone is offline
First only works with plug-ins obtained through the Avid Marketplace.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 09-09-2015, 06:12 PM
thinking about splitting my SSD into two partitions and doing Win 8 or whatever they "support". That plug in thing is annoying but Thump is an Avid one I thought that would work for sure! I'm a guitar player need my Amplitube! Can't even get to the XPand2 plug in always goes to a "page cannot be found". Oh Avid.
Old 09-09-2015, 06:24 PM
Using a supported OS is in your best interest. But changing operating systems will not change which plug-ins First can use.
Old 09-09-2015, 06:55 PM
Southsidemusic's Avatar
You should download Xpand2 from Avid Marketplace inside PTFirst as thats the only way to get it working even though you already have it beforehand.
Thump is Not a Avid olugin, its a Softube made plugin offered free to PT users as a gift to use. Not gonna work in the PTFirst version at all.
Regarding Amplitude and ALL other 3rd party plugins won't work in First! They only plugins that works are the ones that can be purchased in the Marketplace.
Remember that PTFirst is a free version of a very expensive DAW for people to try out a bit and get to know how PT works, if you could use it as a Normal PT version then it wouldn't be free.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 07-28-2016, 10:27 AM
Arden916 Arden916 is offline
How do you go about setting protoolsfirst.exe to run in Windows 8 compatibility mode?
Old 07-28-2016, 10:54 AM
Benoni's Avatar
Benoni Benoni is offline
You should not need to do that. I have PT First running fine on Windows 10. Your results may vary, and it may not be approved, but it should work.
If you want to run in CM, right click the PT icon>Properties>Compatibility Tab
then check the box to run in CM mode and set the target version, APPLY.
Pro Tools 11 on Windows 7 or Windows 8? ianbee Windows 6 08-15-2013 05:04 PM
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) miek07 Windows 3 07-26-2012 08:49 PM
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 05:22 PM
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system rhodamorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-21-2010 06:31 PM
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2009 09:24 PM
