HD Omni Noise Issue at the inputs
Hi. I recently bought an Avid HD Omni & I'm getting an issue when I try to record guitar or vocals. I'm getting a little hum noise at the inputs. I thought it had something to do with the preamp, even when I press the knob under the preamp display...I try to disable the preamp & I cannot go below P1= +10. Is that normal ? Is there any way to disable the preamp ?
I used the input at the back as I am already using a UAD La-610 for preamp. Just to be sure it was not a cable problem, I tried the same set-up on another audio interface (Profire 2626) & I don't get any noise. Any suggestion ? Thanks |
Re: HD Omni Noise Issue at the inputs
Are you connecteing your LA610 to the line input 1, 2, 3 or 4 on the backside of Omni? Have you selected Line on the Preamp section (front side)? Have you tried to set the Reference Level to +4dBu in Hardware setup->Analog In ? |
Hi.
YES I,m connecting the LA610 output to the line input 1 on the backside of Omni. I also selected Line on the Preamp section. I also tried the other options in case. For the Reference Level to +4dBu, I will try it on for sure & get back to you. Another question, if I need to plug a synthesizer directly at the inputs (say input 1 and 2), should I select LINE on the preamp section too ?. Thanks |
...add more inputs to OMNI | mandal | Pro Tools HDX & HD Native Systems (Win) | 28 | 03-20-2017 09:51 AM |
HD omni preamp inputs | Xozz | General Discussion | 3 | 06-09-2014 11:02 AM |
HD Omni inputs | vin7 | Pro Tools HDX & HD Native Systems (Win) | 4 | 03-04-2013 08:36 PM |
HD OMNi + 8 pre Adat how many inputs? | Claudioska | Pro Tools HDX & HD Native Systems (Mac) | 6 | 02-18-2013 08:12 AM |
OMNI question - # of inputs | ianmiller | Pro Tools HDX & HD Native Systems (Mac) | 2 | 12-27-2011 07:34 PM |
